Discuss Alpha 280P/E Advice Please in the Plumbing Jobs | The Job-board area at PlumbersForums.net
RDS
Hi all,
Got an Alpha 280P with hot water tap open the boiler firing but water only running luke warm, but when heating on and hot tap open water running nice and hot. I'm assuming diverter valve knackered? But not sure why?? Any advice would be much appreciated :)
If the flow pipe gets hot when heating off but running hot tap its the diverter valve you can also isolate flow and return valves to confirm and get hot water, haven't come across one of them for years bit hit and miss using repair kit but Alpha parts expensive
If hex was blocked, surely hot water would be lukewarm regardless of whether heating on or off?
New boiler going in end of year with building work going on, but customer wants to keep boiler going til then. Looks like new diverter, plenty of room to work in there at least!!
That boiler is very similar to the Baxi 105 (different gas valve + pilot light) . I agree with the posts above. Most likely going to be the diverter.
Reply to Alpha 280P/E Advice Please in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi There was no shut off valve on the tank feed to the hot water cylinder, and I needed to move a couple of hot water pipes, so I shut off the mains water, turned boiler off (Remeha avanta) and opened the hot kitchen tap to drain the cylinder. After doing the work etc, Everything up and...
Hi, I have a Vailant EcoTec Boiler with a Megaflo. These are controlled by a Honeywell controller. I have one 3 port diverter, where one of the outputs goes to a 2 port diverter prior to the Megaflo (I believe this is some safety feature). I have run into an intermittent problem where some...
Hello. My mixer shower (non-electric) recently started running luke warm. I know this can happen at this time of year over winter but I've been in the property over 10 years and it's never been this bad before. The combi boiler was checked and is ok. The hot water from taps is uneffected and...
PLUMBING ADVICE NEEDED Combi boiler in our house, downstairs water seems to be piping hot. Upstairs basin, bath and shower only ever seems to be lukewarm - so much so that no one even wants to bath as it never gets hot enough! Open to suggestions as to what it might be and if anyone can...
I recently installed new hot and cold feeds to a new downstairs cloakroom. After refilling the system the hot taps were all dribbling, spluttering and showing signs of an air lock. I attached cold mains to a hot tap and left it running for 15 minutes, while opening up each hot tap. They all...
