Discuss Any ideas how I remove this valve cover? in the Central Heating Forum area at UKPlumbersForums.co.uk.
  1. Jpl
    Jpl New Member
    hi, I have 1 radiator which won't warm up. Watched a few guides and think I have narrowed it down to the trv valve. Only problem is I can't get the valve cover off to check the pin. It's a myson valve if that helps, probably very old.
    Any help would be appreciated and thank you
  2. snowhead
    snowhead Well-Known Member
    Push the black spring clip to the left
    • Agree Agree x 2
  3. ShaunCorbs
    Give it a wiggle and pull should pop off
  4. Jpl
    Jpl New Member
    Shaun you are awesome. Was worried to pull it too much before but a good wiggle and a bit of force sorted it. Pin was indeed stuck and thanks to you I now have a lovely hot radiator.
    Absolute star
  5. Harvest Fields
    Harvest Fields Trusted Plumber GSR Top Contributor!!
    Surprised it came off in one piece to be honest.:p
    • Like Like x 1
  6. SavageW
    SavageW Plumber GSR
    Weren’t sure you was talking about removing the TRV head for a moment :eek:;)
  7. firemant
    firemant Plumber GSR
    have you decorated (blue & white) recently :)
Loading...
Similar Threads - ideas remove valve Forum Date
Bathroom suite ideas? Bathrooms, Showers and Wetrooms Apr 2, 2018
Water in Oil tank, how to remove ?? Oil and Solid Fuel Forum Jun 5, 2018
