Discuss Any reason 1/2" Portsmouth (Part 1 ballcocks or FOV) are still sold at all? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Ric2013
To cut a long story short, I started reading the the WRAS Water Regs book again:
G16.1 d states that a G1/2 size valve (do they mean a 1/2" valve as opposed to, say, a 3/4" valve?) must be 'constructed so that the water shut-off level may be altered [...] without bending the float lever.' So why bother making Part 1 valves of that size at all?
I suppose you could argue that replacing a valve does not constitute installing one so you can fit a non-compliant valve as a replacement? Is that why these are still sold?
Just wondering as usual :)
Thanks,
Ric
Part 2's are only made in G1/2 & 3/4 sizes so if you want anything bigger it is still the Part 1.
Also Part 2 is limited to the orifice size that can be fitted I seem to remember.
That's my point: specifically, why bother making the half inch? What does the G stand for, by the way?
R
Many existing WC cisterns still in use have a Portsmouth float operated valve (part1), when the valve is in need of replacement the use of a part2 will not fit due to its air gap back flow protection of the water outlet at the top by means of the bent plastic water delivery spout sticks up too high for the cistern lid. The part 1 can be installed providing back flow protection is installed in the supply pipe in line with The Water Supply (Water Fittings) Regulations 1999.
Where I've seen this though I just replace them with a side entry adjustable arm float valve tbh.
Again if there is space, I would update to part 2 unfortunately at times someone has cut the hole in the F & E to near the top.
Reply to Any reason 1/2" Portsmouth (Part 1 ballcocks or FOV) are still sold at all? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have read a few threads including one by Debbie Stano that were similar to my issue but that thread stopped a while back without any resolution I could see. I'm in Brisbane, Australia but I'm after general ideas from anyone here or in UK (I realise this is a UK based site). Point form...
Hi. DIY guy here, not a plumber of any experience. I would be grateful for constructive critique of the drainage design presented by this diagram, accompanied by the following notes and questions: 1) On the left is dishwasher, on the right is washing machine. Purple lines represent standard...
2K
Good day everyone, I'm coming to this forum in the hope that the collective minds can help me. The story is long, depressing and complex so I'll try to condense the issues for you all, and hopefully you can steer me in the right direction. Thanks in advance for reading the below tale... We...
8K
Hi All, I am so glad I found this forum whilst looking for advice on the net. I am not a plumber as such but I do know a thing or two about DIY. Our house is a 1937 built detached which had a central heating system installed in probably around the early 80's, originally oil boiler system. But...
6K
  • Locked
Hello i'm new to the forum, I've done a little searching on here and still have questions. Some history... I had 11 double rads in my house then i extended the house and added underfloor heating and 4 more double rads, the extension was all plumbed in and has been running for a year now. My...
3K
