Discuss Anyone ever change works of gate valves? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
WaterTight
Subscribed
If so, how often do you find your replacement is compatible with the original?
Are there different brands that vary enough that having one of a each/a few raises chances of success a lot? If so which ones?
Cheers
I change the lot as you've got to drain or bung it
If there is movement in the pipes, then no point trying to swap the works.
I do sometimes just swap the valve body and use the existing nuts and olives if the olive is not a bigger distance onto the pipes and if the nuts are identical threads (usually are) and also not corroded.
But to do a really good job I now replace them with lever valves if the customer deserves it or wants it
Reply to Anyone ever change works of gate valves? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
