Discuss anyone recognise these filters in the Plumbing Jobs | The Job-board area at PlumbersForums.net
ambrosia
can anyone explain these filters to me, if you slide the bar across does that isolate that side and can you remove that filter to clean. also what type of filter is it likely to have inside
the isolation valves either side were seized and as i didnt know what i was doing, the pipwork was 4 inch and the feed tank was 14 floors above me i'm ashamed to say i legged it, but i'm going to have to go back at sometime
To a booster set ?
no cold storage tank on roof, nothing as modern as that in this plant room, just lots of asbestos and decay.
that particular filter goes to the caloriers, but theres 3 others on the heating. theyre having problems with the water supply, thames water are trying to riggle out of it and i'm supposed to take that filter apart to prove its not blocked which i already know it isnt
i just neve seen one of those filters before and they are massive
Normally just a screen mesh and they do tend to require cleaning depending on stat of tank etc
Only one filter / side is used at s time
And you should be able to service live if the seals are still ok
The handle is your filter selection eg left or right
So atm the one by the tanks (red) isn't being used
Open drain off and confirm it's off etc then open up and inspect etc / clean
Reply to anyone recognise these filters in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone, I've joined the forum today as I've found myself going round in circles with what I think might be a pretty simple problem, hoping someone can help. Our dishwasher is leaking and the manual says this can be fixed by cleaning the water inlet filter. To do this, we need to close the...
Hi All This is following on from thread I made a few days ago but can't seem to find I'm in a bit of a bind with my CH design where I want to sort all of my rads and do some other bits including fitting a filter but I'm stumped on how to drain down due to how the system is put together...
Hi I had to remove the glass panels from this quadrant shower cubicle and I'm struggling to get one of the screens back in place properly. The small glass panel is supposed to slide into the wall channel, and some holes in the side of the channel (inside the cubicle) should align with some...
I have a CH boiler installation with a nice simple vertical condensate drain, down and out through the wall to a pipe outside. All is as it should be but I'm fitting an upgraded external pipe setup to include insulation. The inner 22mm pipe mates with the 32mm pipe just inside the house. It...
Please forgive the length of this post, but I must provide all the information to fully explain the issue. I am completely perplexed! My 43 year oldhome is in the country, on a well. Recently, I had a 20+ year old 40 gallon propane hot water heater professionally replaced. The house service line...
