Discuss Are these fitting used here in the UK? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can anyone please advise whether we use this type of plumbing fitting/stopcock here in the UK....
https://i.*********/V8kvLg8.jpg
https://i.*********/J5Nskme.jpg
Many thanks :)
Looks like a 1/2 extension
And something like that yes
Thank you ....so a yes to the 1/2 extension (are they commonly used in that scenario - in a shower control 'standoff'?)
Was that also a yes to the stopcock with a 'slot end' ? (again if so, are they common?
Yes and no, they are but not normally on show normally if you use a back plate 1/2 extension and then the adapter to the shower valve
Yes two types most common is a straight online service valve but you can get them angled
Reply to Are these fitting used here in the UK? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
