Discuss ariston microgenus 23 mffi breakdown in the Plumbing Jobs | The Job-board area at PlumbersForums.net
sammathias
My mate has a 16+year old ariston which isnt producing heating or hot water. I called around lastnight and gave it a service, hasnt been done in years, burner etc was very dusty. Anyway when i left every thing was fine, 11.2mb pressure on high and 2.5mb low kicking in and out on demand.
I had the dreaded call this morning to say its gone to lockout again, my guesses is thst its struggling to fire up on low heating demand causing it to go to lockout and when i had it all running lastnight it was because it had a chance to warm up?
Does anyone know what readings i should be getting? Anyone else got any ideas id be more thsn greatful. Will be going back this evening.
Give ariston a call before you get there mate. Probably is nothing to do with gas valve or gas. What state where the electrodes in?
Electrodes where abit dirty but cleaned them all up on the service and it was all singing all dancing when i left.
Honestly no because it was all working when i put it together and fired it up. There was a delay on ignition when hottap was turnt on tho...15seconds or so. Is thst normal?
No idea mate. Don’t work on that many aristons.
Don't these have fault codes when they lock out? Or am I thinking of the later model?
New boiler :D
Start with the basics and work from there
Well went again lastnight, the red light which he said comes on and doesnt light is not a lockout light but indeed just a low pressure light.
Expansion vessel dead, faulty pressure gauge and jammed prv. Tried to pursuade him to get a new boiler but he opted for a £110 for the parts. Just hope the flue come off in one piece otherwise hes Damned.
Reply to ariston microgenus 23 mffi breakdown in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I'd be very grateful for any advice. My Ariston microGenus boiler is at least 20 years old. Every few years I've had to repressurize it. I've lost the note I had about how to do that. The boiler has two blue taps underneath. The rhs one turns clockwise. The lhs one is so stiff I can't move...
I am looking to replace my existing Vaillant heat-only boiler with a new Vaillant ecotec plus 630 system boiler (30kW). I have a megaflo hot-water cylinder, a central heating system (serving 21 radiators) and an orangery built last year (6m x 4m) with underfloor heating. Through running some...
Hello can any one give me advice on what the problem is. I have a Ariston microcombi 23 boiler Iv had it since 2003. Iv only spent £100 on parts since 2003 other than this problem it been perfect. When I put central heating on the ignition keeps sparking but it’s lit and heating. It stops...
Deleted member 120897
Having a few issues with my combi boiler, its 14 years old now and due to be replaced as we are building extension, but need to get another 10 months out of the combi yet! Was having pressure and lockout issues and the relief vale had activated couple times, expansion tank is fuel of water so I...
Building Description A new (23 years old) 1 story small block of 7 flats. water enters the building and distributed to each flat from a communal cupboard on the ground floor. From here the water to my flat can be turned off via a stopcock(1) at this location. Water enters my flat which is...
1K
