Discuss ASHP ufh 150mm pipe centres??? in the Underfloor Heating Forum area at UKPlumbersForums.co.uk.
Thread Status:
  1. tridimnaw
    tridimnaw Member
    Hi all, ive installed a fair few ufh systems now, all of which are onto oil boilers. Im starting a ashp system next week and was wonderimg how you all loop the pipe to 150mm centers. So far ww have hand formed the loops to 200mm centers but im not confidend of hand forming beyond that!! Does anyone one have a tool ir tricks thry use??
  2. SimonG
    SimonG Trusted Plumber Top Contributor!!
    What pipe you using?
  3. tridimnaw
    tridimnaw Member
    Its the mlcp that comes with the reliance manifolds from grahams, similaf to maincor as thats what we used to use
  4. Matchless.plumb
    Matchless.plumb Trusted Plumber GSR
    What type of floor do you have ? Do you use any floating sheets?
    We used to build a former out of plywood. It took us 1/2 hour but the distance between the pipes were 200mm.
  5. Chalked
    Chalked Plumber GSR
    IMG_0005.GIF Use a counter flow layout. Go into the room, run round the perimeter, run round at 200mm centres, get to the middle and come back out.
    No problem getting 100 centres. Works better too.
    • Like Like x 3
    • Agree Agree x 2
  6. ShaunCorbs
    love the snail method and you get better return temps
    • Like Like x 1
  7. DougFIDHEE
    DougFIDHEE New Member
    The straight runs are obviously no problem; when you get to the turn form a light bulb shape and carry on. if the outer curves of the light bulb shape are close together don't worry--far better than kinking the pipe!
Loading...
Similar Threads - ASHP 150mm pipe Forum Date
ASHP advice Daikin or Mitsubishi Renewable Energy Mar 27, 2018
Thread Status:
