Discuss Aspirante mixer shower in the Plumbing Jobs | The Job-board area at PlumbersForums.net
wiggers
hi all, does anyone know who makes this mixer it has aspirante written on it. I have fifty flats to work in that all have this model.
Any ideas?
Reply to Aspirante mixer shower in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All, The temperature knob on my Hansgrohe Ecostat S shower mixer has been installed insecurely and is loose when pulled, I've looked at the installation instructions and can't see if a part is missing. Any ideas?
Hi all Hope you can help We have a Gloworm Ultracom 38CXI combi boiler. During the Summer the taps and mixer shower run hot water consistently hot for as long as need be, but now during the Winter when the radiators are on the taps and mixer shower will run hot for only a few minutes and...
We have a pumped shower with a thermostatically controlled mixer valve. My wife complains that when she is having a long shower (hair wash etc) the shower runs at the right temperature for much of the time but suddenly changes to run cold, usually during the hair rinse time, for no apparent...
Hi there, All was good until one day the hot water suddenly started running quite a lot cooler. Putting my hand on the output at the boiler it's still hot there so I'm guessing there's a problem with cold water feeding into the hot water somewhere along the line. I have mixer taps on two...
I need to change my shower mixer and I have a unvented hot water cylinder. Is it sufficient to turn off the mains? Do I need to drain the cylinder? Thanks
