Discuss Avoid Turbulance in Digital shower mixing valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I intend installing a digital shower. The mixing valves would be mounted in the loft. Water feed- Hot 22.mm copper pipe Cold 15mm. copper pipe.
I understand that turbulence can be a problem if the mixer valve is close to my last elbow. What length of a straight run would I need to avoid turbulence. My water pressure is 5 bar. Flow 15l./min. Combi boiler
Any advice gratefully accepted. Thank you.
Reply to Avoid Turbulance in Digital shower mixing valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
