  1. Hi, welcome to the new look UKPlumbersForums.co.uk - Login with your usual login details, or sign up if you don't already have an account. If you post just once, all the advertisements get automatically removed. We have some competitions coming soon, and lots of new feaures.
Discuss Balance loop for body jets in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
Tags:
  1. Plumbdogmillionaire
    Plumbdogmillionaire New Member
    Hey, I am currently installing a wet room with body jets. A total of 6.
    3 on one wall in a vertical row.
    3 on perpendicular wall in triangle shape.
    The diagram I have made for the pipe work is attached. Apologies for the cigarette packet quality of drawing!
    Can anyone advise on wether this would work in balancing pressure out of jets.
    Many thanks
  2. king of pipes
    king of pipes Trusted Plumber GSR Top Contributor!!
    Bit vague there bud what is suppling these body jets is it a pumped supply ? Are you relying on the mains supply how many litres a minute do they need to work . cheers kop
  3. Plumbdogmillionaire
    Hi, yes they are running off mains supply, hot is coming from a 25kw combi.
    I'm thinking the bottom run in the vertical line of jets is not necessary.
    Also I could probably simplify the supply to the triangular one too. But as long as it works im happy
  4. ShaunCorbs
    ShaunCorbs Trusted Plumber GSR Top Contributor!!
    What's the flow rate of each jet
    Your boiler can only supply around 10-12 lpm
  5. Plumbdogmillionaire
    It doesn't actually say, even on the website I got the system from.
    It is a PLUM 3 dial 3 way. It says minimum pressure 0.2 bar. But that is it, no flow rates or anything of the like.
  6. ShaunCorbs
    You should have some spec for the heads / jets
  7. Plumbdogmillionaire
  8. oz-plumber
    oz-plumber Plumber
    It will create more than a balanced loop!!
    I would say more than half your pipework is unnecessary.
    In fact, I would go as far as saying 2/3rd's is unnecessary.
    Back to the old drawing board for you!!!
  9. Plumbdogmillionaire
    Oh well, if it gets the job done, I don't mind spending an extra hour doing pipe work. It will improve my soldering skills!
  10. Plumbdogmillionaire
    Right this is the simplified balance loop. This is gonna work right?? Sorry to be a nooby this is the first time I've needed to do one. The feed is coming in where it say water. You'll have to imagine the pipe between the fittings!
  11. Plumbdogmillionaire
    That's it with pipe, looks about right??
  12. SimonG
    SimonG Trusted Plumber Top Contributor!!
    For the water you will get from your combi it's total overkill. That's if you have enough flow for it all to work.
  13. ShaunCorbs
    Why not make a rectangle out of it instead of the pass over
    • Like Like x 1
  14. Plumbdogmillionaire
    Yeh good point, I was just thinking that, I can just have t coming off the pipe it was passing over
  15. Plumbdogmillionaire
    I'm slightly concerned about having enough pressure for this setup to be effective. There are 6 in total. I think instead I will just have the 3 in triangle and maybe one down below for feet?
Loading...
Similar Threads - Balance loop body Forum Date
Balanced Cold water - Megaflo Plumbing Forum May 15, 2017
Does hot/cold pressure imbalance affect my mixer shower temp? Central Heating Forum Mar 24, 2017
Oil Rayburn 480 kb balanced flue high CO Oil and Solid Fuel Forum Mar 12, 2017
fitting an extra balance valve? Central Heating Forum Nov 12, 2016
Flavor raglan balanced flue fire. Gas Safe Registered Plumbers Only Apr 21, 2016
Tiger Loop overflow problems Oil and Solid Fuel Forum Aug 6, 2017
Abnormal Filling Loops - advice pls! Central Heating Forum May 8, 2017
