Discuss Ball valve gone? Dripping Immersion Tank in the Plumbing Forum area at UKPlumbersForums.co.uk.
  1. Michael Coates
    Michael Coates New Member
    Hi everyone!
    There's an annoying drip in the top tank which is constant. It's not overflowed or anything but I am concerned it will. After reading this forum I came to the conclusion it might be a faulty ball valve (simply going off what other people have said about similar issues). I have no idea what a ball valve is or if it's easy to replace. Anyway, below are some questions from me, if would be awesome if someone could help me understand this unit as I've never even seen one before moving into my new flat.
    So first things first, this is what I have. Please correct me if I'm wrong but I believe the cold water comes in from the middle valve with the red turning tap and the hot water comes out at the top right? Currently the red turning tap is closed as I'm having a hot tap in the bath fitted and is in pieces and it'll be like that for another day or two while some parts are sourced.
    [​IMG]
    Anyway, the drip is definitely in the top part, I can hear it clearly however I cannot get a screwdriver in to the valve to try and close it due to the position of the wall. To get it to stop dripping I turned off all the water via the stop tap in the bathroom. Obviously I have no water now but the drip from the top is gone which doesn't make sense if my assumptions about that being where water goes out of is correct. Surely water dripping down would be from water going in the other direction?
    [​IMG]
    Is the top valve (pictured in detail here) the 'ball valve'? Is it an easy job for a plumber to fit a new one?
    [​IMG]
    Thank you for reading, any help, advice or general scolding for me not knowing what the hell I'm doing is greatly appreciated!
    Also while I’m here, I may as well add that when my toilet fills up after flushing it too has a drip that lasts a long time, though does stop. I don’t think it normal to be honest as it goes on for a long time. Some sort of perished washer issue somewhere maybe?
    Thanks again!
    Michael
  2. rpm
    rpm Trusted Plumber
    • Agree Agree x 1
  3. Michael Coates
    Ah, thanks for clearing that up for me. It's probably not the isolation valve right? That's only there to either allow water out or stop water leaving the tank right? Would a bad ball/float valve have a drip?
    Do you think the fact that the lower red turning tap being off and stopping more water going in (is that right?) is highlighting the problem in some way?
  4. rpm
    rpm Trusted Plumber
    Not 100% with that tank so best I say no more, wait for other replies.
    • Agree Agree x 1
  5. ShaunCorbs
    Yep the ball valve in rpms link will do the job also @rpm@rpm your isolation valve is wrong need an angled 1/2 to 15mm (yours is 15mm equal)
    • Agree Agree x 1
  6. Michael Coates
    Thanks Shaun, you seem very sure that the ball valve will resolve this crappy dripping issue so I'll get on at some local plumbers (Whalley Range, Manchester)
  7. ShaunCorbs
    Also try a penny in the ISO valve ;)
    • Agree Agree x 1
  8. Christopher buzzard
    Christopher buzzard GSR
    Mains water in through the isolation valve (pic 3). This stops water going to the ballvalve, in turn cutting of the hot water once the little CW header tank has been drained via a hot tap. A stubby slotted screwdriver will turn this off. Hot outlet is the gatevalve with the red handle. Turn this off when you don't want to drain the CW header tank when working on the hot water side.
  9. Michael Coates
    So the water goes in at the top and out at the bottom? Everyone I've had round has advised the other way!
    On another forum someone just said "That would appear to be an unvented cylinder. Do not play around with any of the valves or it could explode. (No I'm not kidding)"
    I have the red turning tap turned off at the minute as a hot tap is in pieces in the bathroom until I can get a replacement part tomorrow. After that message I'm now really worried the tank is going to explode - is this really possible? I also have the stop tap in the bathroom turned off to stop the dripping - is this a problem as well?
  10. king of pipes
    Is there water flowing down the overflow if not you have probably dropped the water level in the cylinder by running the hot tap thats why the dripping has stopped , nothing is going to explode your system is a simple vented combination cylinder , just need to replace the ball valve . cheers kop
    • Agree Agree x 1
  11. ShaunCorbs
    No it's a combination cylinder
    It's a compact design open vented cylinder and storage tank
    Let me guess a diy forum ?
    • Agree Agree x 2
  12. Michael Coates
    Correct. They had me very scared...
    I have 3 drips in the flat. 1 is the hot tap in the bath, I took that apart and then realised I had the wrong size rubber washer so it's in pieces waiting for me to get that tomorrow.
    The 2nd is the toilet which after filling up drips for about 5 minutes and then stops. No big deal but I'm guessing it's the same issue as the cylinder, it certainly looks like the ball valve posted earlier only blue plastic. I'm guessing this can also easily be replaced.
    The 3rd is of course the ball valve in the cylinder. For clarification, does my cylinder require a special type and size (can't find any information online about this one) or just any 'Float Valve Part 2 1/2" High Pressure' as posted above?
  13. ShaunCorbs
    That's it high pressure = cold water mains
    1/2 is the tail size
    • Agree Agree x 1
  14. Michael Coates
    Thanks KoP, can't say I know what that means though but happy the dripping has stopped after I turned my stop tap back on so I can use the cold water and toilet again!
  15. Michael Coates
    Thanks to everyone here by the way, some solid and excellent advice that put my mind at rest and gave me the right information for what to buy. I've never seen a cylinder like this or had electric water heating before. On the other site someone mentioned getting rid of it entirely and fitting an unvented cylinder as what I have isn't worth fixing which seems a little... extreme :/
Loading...
Similar Threads - Ball valve gone Forum Date
Slight drip brown water from nut / bleed valve area? Central Heating Forum Today at 11:12 AM
Are isolating valves necessary on cw tank & HWC? Plumbing Forum Feb 12, 2018
