Discuss Banging from hot basin tap when on low flow??? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi if anyone could help that would be brilliant. I've got a long banging noise coming from 3 basin mixer taps but only on the hot side when run on a really rate? I was going to change the tap washers but only being on the hot and all 3 I was wondering if someone suspected anything else going on? It's a boiler with a cylinder system. Thanks!
Is it just this hot tap making the noise or all of them ?
i would check the others as if its just the one its either the tap or washer inside the tap
but if its all its something more
Could be the tap insert at fault replacements are available from Toolstation or screwfix its better to remove the faultly one and take it with you when replacing these they are not universal, also check the ballvalve in your cold water storage tank which supplies your hot water cylinder run your hot water taps to drop the level in the tank isolate the taps and monitor the valve as it fills and then switches off these can vibrate and bang as they close . cheers kop
Thanks for all your replies, just started as a new build plumber so trying to branch to older systems. Don't learn enough on site!
Reply to Banging from hot basin tap when on low flow??? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello All, I wonder if you can help me? I have intermittent hot water low flow from all taps in my 4 bedroom house upstairs and downstairs. I can sometimes recover the usual water pressure by turning the hot and cold water taps on and off which seems very strange to me. There is no problem...
Hello, I’ve been doing my first refurbishment is a two bed flat with a bathroom and ensuite . Learnt a lot and been grateful for input’s especially from Shaun. The customer had ordered swan neck mixer taps for kitchen, bathroom and ensuite. On installing then all the hot water flow is none...
Hi Could I ask for some help with a water flow rate problem. I have good mains water pressure on the ground floor. There is no tank in the loft but an unvented cylinder in the upstairs airing cupboard. A gas heat only boiler. Upstairs I have two en suite rooms. One with a shower and one with...
I'm having a nightmare trying to find matt black wall or deck mounted bath mixer taps with 3/4 fitting that work on 0.2 bar. From tank to tap, I have around 2.4 metres, so a pressure of a little over 0.2 bar. The flow measured from the tap currently fitted is 11 litres per minute. Pretty much...
Hello, I have quite low flow rate for my electric shower (a piddling 5L/min), and would like some tips or advice about how to solve or find the cause. I would like a flow rate of about 12L/min. Here is my set-up: Standard gas boiler (not a combi) in the kitchen, have cold water tanks in the...
Essaboy
E
