Discuss Banging pipes problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
TJB1
My pipework for sink keeps banging when no water is being used .
I've checked all pipework to see if any are loose and those that were I've secured. i live in a semi-detached house and after speaking with my neighbour it seems i can hear the banging when hes using water and he hears bangs when i use mine. i have fitted water arrestor to try solve it and next door has had them fitted by local council but yet we can both hear banging.
any ideas?
Are you sure its yours banging when youre not using the water and not your neighbours?
Im only a DIY'er but just found this online if any of it is relevant?
Water hammer’ refers to the banging noises which sometimes come from plumbing pipework, it's normally one or a series of banging noises coming from the pipework usually when a tap or valve is turned off.
It is usually caused in high pressure (i.e. mains pressure) water systems either when a tap is turned off quickly, or by fast-acting valves on appliances, which suddenly stop the water moving through the pipes and sets up a shock wave through the water which causes the pipes to vibrate and ‘shudder’.
‘Water hammer’ will be made worse by having worn valves and pipework inadequately supported.
Not only is the noise annoying, but it can lead to damage to joints, so ‘water hammer’ should be cured rather than tolerated.
Causes and cures of 'water hammer'
There are four probable areas to look at for the cause of ‘water hammer’, and a number of possible cures - the appropriate cure will depend upon the actual cause and the installation. If the ‘water hammer’ only started after some work was done on the plumbing system or a new appliance installed, start by looking at those areas; however,any change to a plumbing system may start ‘water hammer’ in another area.
Probable sources of ‘water hammer’
  1. Inadequately secured pipework – more likely to cause ‘water hammer’ after new work has been done; if ‘water hammer’ first occurs without new work having been done, check the other possible cures first.
  2. Ball and float valves.
  3. Washing machines and Dish washer.
  4. Worn stop valves.
Unsecured pipework
Mains plumbing pipework needs to be adequately clipped to the surface it runs along, so check along the pipework that it is tightly secured at no greater spacing than every 2 metres.
Don’t forget the pipe runs under the floorboards and any boxed in pipework – in fact, these are possibly more likely to have been left inadequately secured than visible pipes, so you may want to look at these first despite the additional work involved in lifting floorboards etc. Ensure that pipework is clipped, secured and supported at regular intervals using pipe clips of the appropriate size.
Ball /float valves
‘Water hammer’ can result from ripples inside open water tanks where the water level is controlled by a ball/float valve – the ripples being caused by the inflow of water with the result that the valve float ‘bobs’ up and down thus repeatedly opening and closing the valve. This repeated opening and closing of the valve sets up shock waves which reverberate along the pipework causing the ‘water hammer 'effect.
If the water tank is plastic, check that a metal reinforcing plate was fitted on the side of the tank when the float valve was installed (see illustration below) - this reduces the flexing of the tank.
Other than the above, ripples in the water will usually only cause problems if the ball/float valve is worn or if the valve has a low pressure valve nozzle fitted when the water supply is high pressure.
Ensure that the washers and diaphragms in ball/float valves are not worn and that the appropriate valve nozzle is fitted – the latter shouldn't be the problem if the ‘water hammer’ started some time after the valve was fitted.
If checking and repairing the valves don’t cure the problem,one solution may be to fit an ‘equilibrium valve’ instead of the usual valve in the tank or cistern. An ‘equilibrium valve’ uses the inlet water pressure to help close the valve, however they are not all that easy to purchase in the UK.
One way to dampen the movement of the float arm is to attach a small plastic yogurt pot to the float arm using a piece of fairly stiff stainless steel or galvanised wire. Suspend the carton from near the ball so that the top of it is just under the water level. The pot full of water should act as a damper to stop the arm ‘bobbing about’ without interfering with the operation of the valve.
Fitting a Torbeck cistern valve (they are available as either bottom or side entry to suit most types of cisterns) is another possible cure, it will prevent ripples on the water surface so the valve will close cleanly.
The water supply to both of these machines will be controlled by electrically operated solenoid valves which stops the flow of water instantaneously, so possibly setting up the shock wave through the pipework to cause the ‘water hammer’ – however, in most cases the flexible hoses attaching the appliance to the water supply are flexible enough to absorb any shock in the pipework.
Stop valve
Stop valves (stopcocks) and taps can cause ‘water hammer’ if they have loose gland packing and/or worn washer jumpers – taps are actually unlikely to be a problem as they would be closed when the noise occurs.
However, stop valves will generally be open when the ‘water hammer’ shock wave travels through the pipework and the shock wave could well ‘rattle’the valve handle and a loose jumper.
While it is possible to tighten the gland packing and replace a loose jumper, the easiest way to cure the problem is just a case of replacing stop valve.
When all else fails.
There are a number of Water Shock Arrestor on the market –these are relatively simple devices which trap air within the water pipes so that the shock wave in the pipework is absorbed. The unit needs to be installed as close to the source of the problem as possible. Some arrestors include a valve where a tyre pump can be connected to add air as necessary. Water Shock Arrestors are not that common in the UK, you'll probable need to go to a Plumbers Merchant rather than the local DIY store.
It is possible to make a home made Water Shock Arrestor:
  • Take a 30cm (12in)length of 22mm copper tube and cap one end.
  • Connect this vertically into the existing pipework using a compression a T-joint as close to the source of the ‘water hammer’ as possible so that air is trapped in it.
This will act as a shock absorber in the pipework, however,overtime the air will be absorbed into the water so the system will periodically need to be drained down and capped pipe removed so it can be refilled with air.
Unsecured pipework
Ball /float valves
Stop valve
yes mine do bang, ive sat there holding pipes while neighbour turns on and off his taps and theres a vibration coming through, that why i bought the arrestor to try cure it. his also bang when i turn on my taps. i dont hear banging in my house when i use my taps and neither does he in his.
Have you tried slightly closing the stopcock (3/4 open rather than fully) to see if the problem is still there?
As I said I'm only a DIY'er, hopefully one of our pro's can give some sound advice soon.
Yes mate tried turning stopcock down but still doesnt help, it stops when i shut it off. its only started in last couple of months which is puzzling.
Get the stopcock changed if its a loose jumper type that will be your problem
King Of Pipes, Can the jumper come off inside the body causing it to bounce up and down unless its fully closed or do they just become loose and rattle?
Thanks i will get someone in to try that, its got to point where im thinking of paying for my own water supply direct to my property just to try and cure it.
Don't turn the stopcock down! That doesn't usually work and often causes hammer from that stopcock as well as obviously reducing flow. The pressure remains the same.
That is incorrect about it being difficult to purchase equilibrium valves here in UK. No bother getting them. Need to make sure any valve has a brass tail.
i did try turning it down but it made no difference so i returned it to normal.
i just find t weird that we hear banging in others house but no in our own.
Yes the jumper can become detached and bang when water is turned on and off cheers kop.
Reply to Banging pipes problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Desperate for some help! Be a life saver of someone can help as suffer from a high intolerance to noise. Moved into new house 1940s (copper pipes) and having serious issues with banging pipes only when central heating is on. Not when running taps We have a wall in living room that has stop tap...
Hello, purchased a house in February this year and for a few weeks, noticed a loud banging noise which sounds like it is coming from under my sink, but happens when no water is running. I think it could be when my neighbour is either running water or maybe using a washing machine. House is an...
Hi, I've had an on going issue for over a year now and can't seem to get an answer. Hopefully can get some more information from the forum. If I use the cold or hot water taps in my kitchen or bathroom, 10, 20, maybe 30 mins later it sounds as if the pipes have water running through them, as if...
1K
Hi, Non-professional / knowledgeable person here. I'm a Brit in Romania who volunteers for a charity building an old peoples home for needy old people. Out here competence and integrity is harder to come by in a worker, in fact it's hard to find workers at all where we are in the countryside...
Hi, So i have lived in my house for 20+ years, (1990 build) its a detached property, corner plot with various manholes in the garden. In the last year I've noticed i can hear when my neighbor flush their toilet through my downstairs toilet - this is a relatively new thing, so am assuming its...
