Discuss Bath corroded on underside by deck taps and is leaking in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All,
Your help would be very much appreciated. I had a leak a few days ago first i noticed when dark spots appeared through my kitchen ceiling. I took off the bath panel noticed the floor board at the back of the bath by the mixer taps was soaking. I placed a towel underneath to try and dry the area before looking further. I noticed that the silicone by the bath and back wall had come away in a small section (i thought it was a small spot of black mould)
I also found i had a cracked tile so spent the weekend cutting out and replacing the tile and teh silicone around the whole bath.
I have just had a shower and checked and the leak is still there! I have taken a couple of photo's under the bath now and seen that there is some corrosion under the bath by the taps and this is most likely where i have the leak.
Any ideas on a fix. I don't want to replace the bath and taps if I can help it. I have uploaded a couple of photo's to show what I mean.
Your help very much appreciated.
Cheers, Joe
I would say removing the taps and putting some clear mastic between the taps and bath should sort you, also if you can replace the plastic nuts with brass ones
Also best to replace the flexible connections
Thats great, I will do just that. I was hoping for something like that. It might be that there is water just getting between the taps and bath because the corrosion means that there isn't a seal anyone. I will look at replacing the tails also. Push fit or copper? If copper I will need to get a soldering lamp! Thanks for the help.
Copper would be better but if you can't flexible tap connection will be ok
Reply to Bath corroded on underside by deck taps and is leaking in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I'm having a nightmare trying to find matt black wall or deck mounted bath mixer taps with 3/4 fitting that work on 0.2 bar. From tank to tap, I have around 2.4 metres, so a pressure of a little over 0.2 bar. The flow measured from the tap currently fitted is 11 litres per minute. Pretty much...
Hi. Can anyone help me get into this tap? I have them on the bathroom sink and bath and 2 out of 4 are dripping. I've have had two plumbers in to replace the washers and neither could get them open. The gold coloured ring under the top unscrews on two of them but won't budge on the ones that...
Hey guys I know this ain't plumbing. But some of you may know. I have a small bathroom but water seems to leak to the kitchen. I realised under the floor tiles one of the floorboards on side of the bath was wet through and almost rotten. So I feel the water has been seeping through that due...
I have a slow leak in the bath. Its a mixer type set up. I'm unfamiliar with the tap handles and how to access the cartridges etc. If I can work out the product name/brand/type then I can work out how to remove the tap handles (no obvious indices so presuming they pull off some how). Would...
Hi I have a 22mm hot and cold water supply to new bath. The pipes finish with compression valves. I need a 500 mm tap connector hose to connect with half inch thread on the new bath tap. All the connectors at the main plumb merchants are 22mm x 3/4 inch. No one seems able to answer question...
