Discuss Bath draining problems in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. SMB
    SMB Member
    How long should an ordinary sized bath, full to the over flow take to drain.
    It was not completely block, so we used a drain cleaner. The trap is completely clear and is now taking 5mins to drain.
    The pipe is a straight run to the soil stack about 1.75m.
    I think dog hair (don't ask!!!) may be clogging at the end of the pipe where it joins the soil stack. However I don't want to lift the floor unless I have too. Also I can't remember how long it took to drain when it was first put in.
    Cheers.
    SMB
  2. Harvest Fields
    Harvest Fields Trusted Plumber GSR Top Contributor!!
    Depends on a number of things. Does the basin drain ok when full to the top, or is that slow also?
  3. townfanjon
    If you can remove the trap try a plumbers "snake" down the pipe . Its the cheapest way .
  4. ShaunCorbs
    I would say that's about right 16lpm
    • Disagree Disagree x 1
  5. cr0ft
    cr0ft Trusted Plumber GSR
    When I've had problems with baths draining etc I undo the trap and get my wet vac on the waste pipework. Always cleared in seconds. Trap back on and jobs good!
    • Like Like x 1
  6. Stigster
    Stigster Plumber
    This can be very effective. I recently went to a job where the custard lived next to the beach and the bath was clogged with sand from when she gets straight off the beach and into the bath/shower. They had been putting acid down the drain which won't do anything to the sand. Then they tried a drain snake and it didn't help either because that won't clear much sand so I went round with my wet vac and pulled all the sand out in a few seconds. You can buy a decent enough wet vac for £50 these days. I have an Einhell bought around that price. An indispensable piece of kit for a plumber and useful for a householder to own too.
Loading...
Similar Threads - Bath draining problems Forum Date
Bath mixer tap with shower attachment Plumbing Forum Today at 7:10 PM
Advice on Hot/Cold bath mixer Bathrooms, Showers and Wetrooms Feb 11, 2018
