Discuss Bathroom basin tap identification in the Valves & Taps area at UKPlumbersForums.co.uk.
  1. 2005jasp
    2005jasp New Member
    Hello, after some help to try and identify this bathroom mixer tap. The hot tap head has come loose so need to try and fix. The mother in-law says it was homebase but I can't find one on their website. It is fairly old. Hopefully I've managed to attach the photo.
    Thanks from your help.
  2. JCplumb
    JCplumb Plumber
    Not seen that tap before. What's the problem, might be an easy fix.
    By 'The hot tap head has come loose', do you just mean it's wobbly, still works but the handle itself is loose?
    There may be a grub screw at the back or underneath that you can tighten. Maybe the ceramic cartridge is damaged and needs renewing. First thought on the little information I have though is a grub screw. They're usually an allen key type, use a mirror if needed or they're sometimes easier to find with the tap in the open position.
  3. turnpin
    turnpin Trusted Plumber
    When Home base was Sainsburys Home base they stocked some of the Bristan range of taps and showers can't say for sure if it is but might be worth a shot....regards Turnpin
Loading...
Similar Threads - Bathroom basin identification Forum Date
Loss of cold water supply to bathroom - conflicting views on how to resolve the problem! Need advice Plumbing Forum Yesterday at 9:50 PM
Supplier of bathroom furniture required Bathrooms, Showers and Wetrooms Sunday at 11:22 AM
