Discuss Baxi 15-HE Loud intermittent noise in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I
ianleon
My Baxi 15-HE ia making a noise which can only be described as a fog horn/loud rumbling noise ! The issue is that it is intermittent, although it seems to be happening more often now.
I'm not a plumber or gas safe registered, etc I am looking for advice on possible problem identification rather than have someone here all day costing me ££££££'s waiting for a noise too happen.
The only fault finding I have achieved is that it only happens when the hot water is heating, its fine with just the heating on.
Thanks in advance for any help/advice.
either way you need a gas engineer to change the obvious part in question.
therefore its time to save up.
we do not give public advice on faults or repairs to boilers on these open forums.
please refer to the forum rules.
cheers
Reply to Baxi 15-HE Loud intermittent noise in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Desperate for some help! Be a life saver of someone can help as suffer from a high intolerance to noise. Moved into new house 1940s (copper pipes) and having serious issues with banging pipes only when central heating is on. Not when running taps We have a wall in living room that has stop tap...
Recently over the past 2 months, the boiler or area by the water tank has started making a loud groaning noise whenever hot water has been running for much over a minute (sometimes less). Since the weather has gotten cooler, the radiators seem to come on (unless turned off at the TRV) whenever a...
2K
Customer complains of Intermittent heating on Y plan with Stat satisfied. New boiler fitted last year (no permanent live required or fitted previously) on an existing Y plan system. Existing timer was a Randall 103 (no hot water off position as its a timer not a programmer). The customer wanted...
2K
Our boiler makes these very loud rumbling noises every 2-3 minutes. We're quite used to them now but they have become a lot more regular over the past year or so (it only used to happen once every half an hour or so) and they can be quite annoying. Our boiler is a Worcester Greenstar 24I Junior...
2K
Some advice please about a really worrying problem. I live in a terraced 2 bed room house. 10 days ago the gas combi boiler stopped heating the radiators but still gave hot water to the shower and taps. Naturally we thought there was a fault with the boiler. We had already arranged a yearly...
