Discuss Baxi 45/4E back boiler problem. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
Jakey
Have a Baxi 45/4E boiler fault. After running for half the day it fails to fire up. Sometimes lock out light comes on. Sometimes not. After an hour the boiler will work again after turning back on. Ignition seems ok. Could it be thermostatic sensor? PCB? Anyone Know the possible causes of this intermittent fault.
Cheers Jake
sorry to say you cant fix a gas appliance your self you need to be gas safe reg
so sorry to say you require the services of a gas safe engy
Reply to Baxi 45/4E back boiler problem. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I have a Glow-worm back boiler which is giving me grief (I would have upgraded it by now but its a listed building and there's issues with venting through the external wall and I'm reluctant to go with an electric boiler instead (because of the consumption cost)). It's a sealed system. The...
Hi All New to this and a little green around Gas boilers.. So, a house I’m in possession of has an old and trusty Baxi Bermuda 45 back boiler which worked perfectly fine until I isolated the gas supply from the meter box.. After a couple of months and with the weather getting colder, I’ve went...
1K
Hi Guys, Got a problem with a Baxi Solo 3 PFL50 The "pilot on" light is on permanently It was intermittent, but is now permanent When this happened, the boiler would not go through the normal start-up sequence Turn on the control and the 'boiler on' light comes on, but goes no further I...
My Grant combi oil boiler is giving me quite a headache at the moment. When I returned home last Friday I'd no heating or hot water. An engineer called the next day and diagnosed a faulty pressure switch. This was changed and everything seemed ok. However then the boiler began to lose pressure...
Hi, Can I pick your brains? My boiler is often reluctant to start, sometimes it does, sometimes it seems that it will if the demand is from the central heating but not for hot water and sometimes the other way round, so it's probably just luck as to when it does decide to work[?]. When there's...
1K
