Discuss Baxi bermuda pw3. Help on job now in the Plumbing Jobs | The Job-board area at PlumbersForums.net
your on about the boiler...........
its airlocked then y the sounds of it and you pulled out the stat not the thermocouple and its boiling over?
Sounds like bad circulation problem , have u disconnected any fittings or pump Bleed to check colour of water ??
I'd give quick drain n have look at state of water in f n e tank.... defo circulation problem as sounds like overheating as water not moving and cutting out burner . Rads defo open ? Also is zone valve working properly ( if there is a zone valve). Try opening manually n feel how it opens whether freely or bunged up . Prob not but worth a look.
Some of the older tee blocks were made of steel !
They would be magnetic ( if it's one of those ).
How do you know the pump is running ?
circulation problem then, air lock/run dry!
pump on right way?
pipes blocked?
its going to be a days work lol
Manual?
Manual?
You changing the whole system Ash , or it sounds like it needs a really good flush
Reply to Baxi bermuda pw3. Help on job now in the Plumbing Jobs | The Job-board area at PlumbersForums.net
