Discuss bay window radiator question in the Central Heating Forum area at UKPlumbersForums.co.uk.
  1. selondonman
    selondonman New Member
    hello i have a room with a bay window and currently has a single panel curved radiator .. the room is too cold in winter so looking for a replacement
    the curved double radiators i have seen seen are very pricey.. i was quoted over £500 to curve a double radiator
    as the bay is nearly totally covered by a couch .. is there are practical reason why i couldn't put a straight radiator in .. obviously the pipes values are set for a curve and will need to be changed ..
    if the bay is 2m wide would the straight rad need some support either wall or floor in the middle ?
    thoughts
  2. ShaunCorbs
    No perfectly fine aslong as you size it correctly
    But covering it with a sofa won't help
    Are your windows tight eg there not leaking / double glazed ?
    • Like Like x 1
  3. selondonman
    thanks for reply
    windows are double glazed .. dont have much choice re sofa position .. thus trying to find a powerful radiator to try and get over position issues
    it might be easier just to get an upright ceramic heater for the colder nights .
  4. leelister6
    leelister6 Plumber GSR
  5. johnduffell
    johnduffell Member
    Why not move the rad somewhere with a clear wall? Or fit several low output wide rads if you're doing it yourself.
    We did the latter and it's not quite under floor heating but it's a very even heat compared with the old double convector by the window.
  6. steadyon
    steadyon Active Member
    You could put a series of (say) 3 or 5 smaller (narrower) radiators close to the contour of the bay. Link these top and bottom, with valves only on the outside ones and you've got the equivalent of a curved radiator. Would need some skill with a pipe bender to make up 22mm curved joining pieces, each with a 22mm compression / 1/2" bsp male iron on each end.
    • Agree Agree x 1
    • Funny Funny x 1
  7. Harvest Fields
    Harvest Fields Trusted Plumber GSR Top Contributor!!
    Bit messy for me that one. Cannot beat one continual radiator.
    • Like Like x 2
  8. S.P.S.
    S.P.S. GSR
    Just get a nice new single panel rad, lay it between 2 chairs and jump on it
    Curved rad sorted :D:D o_O
    • Agree Agree x 1
    • Funny Funny x 1
  9. Michael1960
    Michael1960 Plumber
    Or get one delivered from a well known on line supplier! They usually come ready shaped
    • Funny Funny x 2
Loading...
Similar Threads - window radiator question Forum Date
Unknown radiator valve Valves & Taps Jun 13, 2018
Radiator Valve Threads Central Heating Forum Jun 11, 2018
