Discuss Bc sanitan basin tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
CP1111
Need to find a replacement for this tap as both spline and cartridge have worn down
Been looking and can't seem to find an identical option, or any that have ceramic piece on crossheads
Believe these aren't made any more, so any advice would be appreciated
Cheers
Bit old I know but I'm about to strip out a load of Sanitan stuff during a modernisation project for a guest house and I can save the taps if you want.
Reply to Bc sanitan basin tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, My Blanco Kitchen Tap Model Swift BM1420 is leaking. Please see attached photos for details of where water leaks from. What I've done so far. I replaced the cartridge. Leak persisted. Bought some replacement seals and tried to put in place of the old ones. Here's what I did next. Remove...
I am trying to replace the cartridge for a waterfall tap (mixer mono) for the bathroom sink, I have run into a problem whereby I cannot remove the cartridge as the usual 32mm nut is recessed and I cannot get to it. The tap is from screwfix ( NIAGARA WATERFALL BASIN MONO MIXER TAP) I have...
J
I have what I think is an older style Mondella/Watermark mixer tap that needs the cartridge changed. I have done this many times on my taps before, but on this unit, I can't find the screw that releases the end cap. Any advice - other than replacing the unit - would be appreciated. I would...
Deleted member 120897
Hi. I have Charlton Mixer Tap in my shower i.e. thermostat and water control. I need to change the cartridge in the tap as it is dripping badly. However, I'm really struggling to access the cartridge. The way to remove the tap appears to be to unscrew the chrome covering i.e. this will bring...
My bathroom Basin was installed some years ago by a professional plumber. For whatever reason, the waste was fitted using silicone rather than plumber’s mate. The floor was originally tiled, but I replaced it with high quality vinyl, when fractures began to appear in the grout. As part of this...
