Discuss Beaumont Sequential Shower Valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Barlamb
I have a Beaumont Sequential Shower Valve and the tap is leaking. I live in a hard water area and guess it is probably clogged up with limescale. Can anyone tell me how the valve/tap comes apart? Many thanks
Without loking at it, it is hard to explain.
You will need to dismantle it pretty much the same way as a Pillar Tap....
1. Isolate the water supply
2. remove the valve cover and expose the retaining screw.
3. Un do the retaining screw and remove the thermostatic cartridge.
4. Replace cartridge on a like for like basis.
5. Reassemble the valve assembly and turn water back on.
Job Done :)
OK you know what you're talking about but I haven't got a clue. I understand isolate the water supply and take out the retaining screw but which bit is the thermostatic cartridge. It has a single lever tap and a round gold part in the centre - is this the thermostatic cartridge and should it just pull off quite easily? Many thanks
Reply to Beaumont Sequential Shower Valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Guy's, Looking for some advice on an issue I have having with a recently installed thermostatic mixer shower in my ensuite. Everything was working fine for a coupe of months however now the valve has started misbehaving which is resulting in having to turn the temperature valve round further...
T
I am redoing my bathroom and not sure what the best way of doing my shower is which is in my bath, I want a rain shower and so I was thinking of using a thermostatic shower valve as I have removed the plasterboard to re tile (new build) and thought this is a good opportunity to do it, my...
Thermostatic shower
T
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air gap as I was having dripping from the pressure relief valve. Since then I've lost a lot of pressure from the hot water feed to my shower. The rest of...
Hi All I had an unvented cylinder fitted about 6 years ago. It only supplies hot water to my shower. I was hoping for a much better flow rate from the shower but it seemed no different from the original combi boiler hot feed. There is (unusually) a lever that lets me select the combi or the...
Steveo111
Hello. My mixer shower (non-electric) recently started running luke warm. I know this can happen at this time of year over winter but I've been in the property over 10 years and it's never been this bad before. The combi boiler was checked and is ok. The hot water from taps is uneffected and...
