Discuss Bedding in a stone resin tray in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
Thread Status:
  1. jonna
    jonna New Member
    Hi all, I'm looking for some advice installing a stone resin tray..
    Previously when I've installed these I've bedded them into tile addy on top of ply but they've always been the flat bottomed design.
    The tray I've installed on this occasion has a recessed/contoured bottom and it's on top of a timber platform topped with 18mm marine ply. I contacted the manufacturer (Simpsons) who stated that the tray would need to be bedded into a sand/cement screed. I asked if this needed to be a solid bed of a given depth, or spread using an adhesive trowel and I was informed that an 18mm trowel would be ideal. On Tuesday, I installed the tray using a wet mix (4:1), but I'm concerned that it's going to fail.
    Having installed the tray I put what was left of the cement on some scrap ply as I wanted to check how well it adhered and gained strength. The cement on the scrap ply when examined today is set but is not strong - there's no strength to it at all and it can be crushed back to sand with minimal effort.
    My concern is that the cement under the tray is in the same condition (weak and poorly adhered to the ply) so I'm considering relaying it.
    Question is, how should I do this given that I've followed the manufacturer's instructions already to this point?
    Thanks.
  2. ShaunCorbs
    did you wet the bottom of the tray before you applied your mix and test board?
    • Informative Informative x 1
  3. jonna
    jonna New Member
    No I didn't wet the tray. The only thing I've considered doing differently was using a drier mix and use more of it. The mix I used had to be pretty wet in order to make it spreadable with the adhesive trowel. I assume by wetting the bottom of the tray, I'd help avoid the cement drying out too quickly - of the two materials though, (ply/stone resin) surely the ply would be more aggressive in leaching the water out of the screed?
    I'm half tempted to relay it using tile addy, but from what I've read manufacturers recommend sand/cement as it's stronger and less likely to crumble/fail over time. I could go back to Simpsons and query it with them I guess?
  4. Best
    Best Trusted Plumber
    It is more a bedding material and not an adhesive. Unlikely the tray will move. All that matters is that the adhesive sets to some extent. Personally I don't like sand & cement mix method that tray manufacturers recommend. Ordinary sand grit size can make a fairly course mix IMO.
    Remember that sand & cement will weaken if it gets drying too quick, because it needs a chemical reaction over a long as possible period. Putting a small amount on a piece of plywood will dry it quick, causing it to be weaker.
    Cement needs to be fairly fresh and don't use more than specified amount of mortariser, if any, and washing up liquid that people often use will also weaken the mix severely unless just a tiny drop
    • Like Like x 1
  5. Best
    Sand & cement does tend to crumble on wooden floors.
  6. jonna
    jonna New Member
    Any suggestions on overcoming this? For reference, the base I've built is raised slightly to allow access to the waste and is topped with 18mm marine ply...
  7. jonna
    jonna New Member
    I take your point about it just being a bedding material as opposed to an adhesive. I guess I'm equally concerned about the strength of the screed. What do think to the suggestion of relaying, but using a solid bed with more mortar? I'd hope that by doing that, the base would retain moisture for longer and gain more strength..
  8. jonna
    jonna New Member
    It would raise the tray further, but how about I fix a cement backer board to the ply, then screed and sit the tray on top of this? Over the top? bad idea?
  9. Harvest Fields
    Harvest Fields Trusted Plumber GSR Top Contributor!!
    I have a few questions?
    Is this a low profile tray or on a riser kit?
    If on a riser is it a frame that you made or is it a metal one that came with the tray?
    Did the manufacturer supply the boarding?
  10. jonna
    jonna New Member
    The tray is a Simpsons 45mm stone resin model which is advertised as low profile. The tray 'can' be mounted on a riser kit, but I decided instead to build a solid timber frame as per previous installations. The frame I've built consists of 2x4 timber with 18mm marine ply on top.
  11. Harvest Fields
    I use a 4:1 or 5:1 mix when I spoke to the manufacturer of the very first one I did, they said that it does not need to set solid it needs to have a slight bit of movement in it. That is why some trays are set on flexible floor tile adhesive. I have done more than a fair few like this now and never had an issue. You should be fine. In my opinion.
    • Agree Agree x 2
  12. Best
    Keep your tray as low as possible. I also think you should be okay with the way you have done it, so leave as is. Have confidence in your work.
    I have put a lot of trays in and many of them are fairly weak bed, but no problem with them. Think of it as a layer of trapped sand below the tray, - the tray has a soft bed, but the bed will not move away from beneath the tray.
    Any big gap around the edge bed, if it is crumbly, just scratch it out with a screwdriver or something and use some sand and cement mix with a bonding agent in it, if you want.
    • Agree Agree x 1
  13. Phil
    Phil Plumber
    Who on say a 1600 x 800 tray puts the waste by the wall or to the edge near the door.
    What are peoples preferences? I nearly had to turn mine round after it was fitted last week.
  14. Harvest Fields
    I always put it where it will be easily accessible.
    • Agree Agree x 2
  15. jonna
    jonna New Member
    Thanks for the vote of confidence. I think I'd feel happier if the thin bed I laid the tray on was solid, based on what I've read the last day or so. Having applied it with an adhesive trowel (as advised by the manufacturer) I'm thinking the 'strips' of cement screed are more likely to crumble and move over time vs a solid bed. I'll see what it's like to stand on tonight, but right now I'm considering lifting it and laying on a 10mm solid bed...
Loading...
Similar Threads - Bedding stone resin Forum Date
Radiators hot upstairs, stone cold downstairs Central Heating Forum Mar 14, 2018
Thread Status:
