Discuss Best budget unvented system boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
michael c
Hi guys as above, what is the best budget price unvented system boiler on the market at the moment?
I'm trying to price up for a customer but it's been a long time since I changed one of these. The customers current boiler is a cheap make with all sorts wrong with it and will cost a minimum of £300 in parts alone plus alot of work to get back to good condition.
They have a limited budget so trying to find the best compromise for them.
Best or budget what do you want?
How much do you want to spend
When I've looked ideal do one with 5 years warranty which from Williams and co total cost including a magna clean would be around £830 but I have no experience of this boiler.
Intergas are a similar price but I'm not sure how long the warranty is as I am not one of their platinum registered installers.
Main (I'm a baxi man) are cheap for a system boiler but would require an expansion vessel, prv and gauge fitted extra which isn't really practical.
So really for boiler and flue budget is around £800, looking for the best boiler for compromise between warranty, reliability, cost of parts etc.
Their current boiler is 24kw so looking to exchange for same size (although it is only a two bed property)
Cheers clarky, I hadn't received any advice so decided to push the customer to go for a baxi megaflow 24he ERP. Got the boiler,flue,magnaclean and chemicals for £994 from plumb centre.
I could of gotten an ideal independent for much cheaper (was told it's the same as a logic, just only available to independent merchants and not national chains) but I'm not a huge fan of ideal boilers.
Reply to Best budget unvented system boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My daughter bought her first home and was hoping to convert to gas but its not available in the area, so thinking a boiler upgrade is the better way to go. Just after some advice and rough costs involved, is it worth getting a pressurised system installed and a new boiler and oil pump? Heating...
Hi, i've got a job with a Vaillant Ecotec 630 system boiler, and i don't know the full history but the house has definitely been extended significantly since the boiler was installed. There's now 21 radiators/towel rails. It's getting to temperature, but even after balancing, it's not heating...
Hi All, We have finally decided after a bit of a persuasion to have installed a utility room in our garage that currently houses our oil boiler. Initially we thought the boiler may stay in place but after discussions with the builder we would have to move the boiler to replace the floor and...
Hi All, Looking for a bit of advice on the best way to pipe this. - 24kW Worcester regular boiler in kitchen, approx. 9 years old - unvented tank, zone vavles, pump, expansion is on first floor in airing cupboard - Currently piped as S-plan. - Hive controls. - Would like to fit 6-zone...
We need an urgent advice, we have a gravity water system and we are in a middle of loft conversion. We are adding an en-suit in loft and prefer to have a good water pressure there. What we want, is to either be able to run multiple showers at once, or if one person is having a shower, other...
