Discuss Best fittings for lead in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Scott_D
Subscribed
I need to replace some lead water main in a house thats being renovated
Its approximatly 20mm OD
What are the best fittings to use?
Lead Loc or a universal fitting like plasson or philmac?
On a house that is being renovated I would want to remove all lead work, - at the very least to outside if entire underground mains not to be immediately replaced.
Philmac I have used on outside pipes
universal fitting not hassle i like philmac but thats me
I am going to cut where it enters the property and recommend they get the external pipework updated.
Whats the likley Internal diameter of 20mm lead?
14-16mm ish
Hi Scott my personal choice would be a lead loc...not 100% sure as I've not used a Philmac transition coupling but I believe you have an element of adjustment when it's tightened up.....someone will correct me if I'm wrong all I would add is to position it where you can get at it in future i.e. Not behind kitchen units.....regards Turnpin:)
Sound advice from Best as per normal.....regards Turnpin:)
Reply to Best fittings for lead in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Fitted unvented hotwater cylinder building control looking forms signed it off job was in england i am qualified northern ireland send out a form to fill in what do u need to sign off in england as building control said they dont give out forms like they do in northern ireland
