Discuss Best value porcelain/ceramic tile hole cutter? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Jim Goodenough
I'm needing to buy a 16mm & 51mm porcelain/ceramic tile hole cutter for infrequent use - what are the best value products on the market?
Also which is best, cordless drill type OR M14 cordless grinder type?
rubi
I love the Rotozip X cores , but I think they are now marketed by Bosch.
Will try find out and post back
I am very impressed with the B&Q diamond edged hole cutters for toughness and value for money.
Full kit best value, if they still do them.
I bought a couple of cheapies from Screwfix - they've worked fine on ceramic however I bet they won't cope with porcelain.... we'll see :rolleyes:
I use Rubi as well. Also use a rubi discs on my mini grinder. Awesome bits of kit. Not the cheapest though.
I've a Marcrist diamond blade for my Makita cordless mini-grinder, it's the EXTRA thin type designed for 'cordless'
I reckon it's time you splashed out Harvest! :)
You'll be amazed at the power of cordless nowadays!! I recently bought 4no. 5 Ah (18v) batteries for my Makita LXT gear - they're incredible.
People like DeWalt & Milwaukee are sporting 8 / 9 Ah batteries now... you can put your extension leads into the darkest corner of your van now... :D
But my 240v Dewalt are awesome mate. :(:p
Reply to Best value porcelain/ceramic tile hole cutter? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Sticky
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
