I have got to remove a toilet and cap off the cast iron waste. It is half buried on a concrete floor so not easy to cut, how do you normally go about capping or plugging these. All I can think of using would be a 4 inch bung like used to testing?
Discuss Best way to cap cast iron soil pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Do you need to use the drain again ? if not bung some newspaper down and seal with sand/cement.
How about Drain Connector with 1Ā¼"/1Ā½" Ring - Drain Connectors - Waste Pipe & Fittings | McAlpine Plumbing Products with an 1 1/4 rodding eye.
Reply to Best way to cap cast iron soil pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
