Discuss Black 40mm compression waste fittings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
gassed up
Why is it impossible to get hold of these or am I not looking hard enough?
Probably have to be ordered in, don't think I've ever used one
Reply to Black 40mm compression waste fittings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Trying to connect up new 40mm waste into the old soil stack (which would be an absolute pain to remove), it's all Osma pipe, from the 70s. Pulled out the old waste from the boss and discovered the seal is pretty knackered, hardened and cracked everywhere (red coloured seal in the photo)...
1K
Hello, I'm considering fitting an isolator valve to 15mm feed to my toliet cistern. It would require cutting off an existing compression fitting for a flex hose, after which I'd only be left with maybe an inch and a half of pipe. I've never fitted a compression fitting before, can someone...
J
Hi All, I'm plumbing in a washing machine into our new house and rather than a normal waste pipe this house just has a hole in the ground. It looks as if the hole used to be a 40mm pipe but it has been sawn off at ground level such that the top of the pipe is flush with the floor tiles. This...
Hi, came across this old push fit waste pipe. Stripped out the old shower and it was a 40mm waste pipe siliconed in the fitting. The fittings at floor level so I’d be looking to bend (90 degrees) straight away so I can get the lowest possible shower tray. Could someone advise what I could...
Hi, just hoping someone can advise on best option to connect 40mm waste pipe to a flexible bath waste hose of approx 30mm, I assume some form a spigot to will needed but not sure exactly what to search for. Many thanks in advance!
