Discuss Black valve in image in the The Welcome Wagon :) area at PlumbersForums.net
Hello, I would like to know going by my image supplied if that black valve is open or closed? I would also like to move it so I can dangle the power cable so it doesn't touch anywhere near that hot pipe.
Is it normally left in this position?
[automerge]1582538148[/automerge]
As you will see I have it pushed out slightly with a swab, but I would prefer to have the power cable dangle freely, it's a logic combi boiler esp1 35
No your fine as itā€™s double insulated
Well invest in a few cable ties and secure it away from the pipe for peace of mind.
To be honest and as per my image there's not much cable length, though I'd already cut a swab and inserted it in place which pushes it away from the pipe.
Other course of action is moving the valve, upping the cable away from its current position, opening the valve again and I'll see what options I have then.
Reply to Black valve in image in the The Welcome Wagon :) area at PlumbersForums.net
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
