Discuss Bleeding a radiator for the first time in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello I am trying to bleed this radiator. Can you please post which key I need to bleed? Or hat tool do I need ? Thank you.
Top right and you need a bleed key
If you have a combi boiler or sealed system you may have to top the pressure back up , if you have ,
find out how to before you bleed the rad .
One of the bleed keys as shown further up the thread
Look at the simple bleed keys at the top of this thread. Plenty of space to fit one of them in. Quote for what? A bleed key?
The size of that air tap key I posted is only 1 1/2" wide.
If you can get a screw driver in the slot, use that.
You only need to crack it open though, don't be tempted to pull it all the way out.
Reply to Bleeding a radiator for the first time in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Fitted unvented hotwater cylinder building control looking forms signed it off job was in england i am qualified northern ireland send out a form to fill in what do u need to sign off in england as building control said they dont give out forms like they do in northern ireland
  • Sticky
