Discuss Blocked oil feed pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
RUPERTC
10 M of copper 8mm oil feed pipeline from tank with only a 1m head.
Oil not reaching boiler.
Replaced filters.
Is there a way to rod such a small pipe?
get your suction pump on it or blast it out with a compressor (with other end tied into a rubble sack)
I assumed the fire valve etc is clear and not in the line
Replaced filters.
Think the boys use a compressor for this.
DO NOT PUT A FINGER OVER THE END OF THE PIPE WHILST DOING IT! !!!
Have you dipped the tank to make sure there is plenty of fuel?
Reply to Blocked oil feed pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
