Discuss Boiler briefly calling for heat after shutting cold water tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hi guys any help or advice would be good, I have a Ariston Clas eco he 30 combi boiler it’s only 9 moths installed but just noticed that it occasionally calls for heat if just after the cold water tap is closed it’s litteralky a second the icon for head comes on n then off I’m assuming that’s not a normal function I know you can hear the valve open n shutting but the brief signal for heat isn’t normal is it plus will it be doing any harm to the boiler?
Fit a double check valve on the cold supply to the boiler with a mini shock arrestor between to protect your boiler this will stop it . cheers kop
You possibly have some poor pipework somwhere ie a section capped off leading off a tee , some boilers do seem prone to this . If you cant sort the pipework a mini arrestor should sort it .
The flow switch in the boiler is sensing movement of water in the supply which feeds the boiler stop that and it will sort the problem out , a mini arrestor protects components on the hydroblock within the boiler personally i would get it done under a £100 fix , get a leak inside the boiler it could be very expensive. Cheers kop
Guys just an update in case you were loosing sleep basically it was what was expected deal leg where old cylinder was my neighbour is a plumber but we would need to lift floors to get all the old pipe out so he stuck a fitting on n bled it as was full of air n boom all good no longer is it asking for heat, thanks for all the help guys
Reply to Boiler briefly calling for heat after shutting cold water tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Hi, we have a back combi heater. Whenever the heating comes on it seems to lose pressure within a few hours and I have to refill each morning. The boiler seems to function well, and the pressure only drops with the heating and not the water being on. Ie it started last winter and was then...
Hi all. As the title says, I have a problem with an unvented cylinder I had installed last year where the first time I turn a hot tap on after the cylinder has been heated I get what sounds like a vibration. It generally starts about 1s after I open the tap and lasts for about 1.5s. I've...
2K
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new well maintained Worcester combi boiler. We weren’t convinced the heating was working right and then got hit with a £610 energy bill for the first 6...
MartinPod81
M
I have read a few threads including one by Debbie Stano that were similar to my issue but that thread stopped a while back without any resolution I could see. I'm in Brisbane, Australia but I'm after general ideas from anyone here or in UK (I realise this is a UK based site). Point form...
Hoping somebody can help, So, in a nutshell… Standard 90s Westbury home – condensing boiler, pump, wall thermostat, etc etc... Normal, common or garden, run-of-the-mill British housing estate CH setup. Downstairs radiator, 1 of 2 in our living room, went cold one evening mid-November last...
