Discuss Boiler Combi 24, pressure indicator always pointing to 0 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a Boiler Combi 24 (UK) and this morning I just noticed that the pressure indicator is pointing to 0. However everything is working fine, I have heating and hot water.
Usually when the pressure is at 0 the boiler indicates (Failure) and there is no heating / hot water..
- I have tried to reset the Boiler but no luck
- I have tried draining the boiler, once all the water got out the Boiler indicates Failure, which is fine, and then I have open the looping thing to make the pressure go up. It did go up because the boiler started working again but the pressure indicator is still stuck at 0.
Can someone explain me why the indicator is always at 0 ? Is it broken ? Is there something stuck in the pipes ?
(Note that 5 days ago I had a new shower installed in my bathroom and some plumbing work was done in there, not sure if that can help debugging the situation)
Oooo ideal might be the gauge is faulty
Is it on zero or has it has gone all the way round
Your pressure gauge tube connecting it to the boiler is probably blocked with debris. Sometimes it is possible to remove it, clean out the connection it comes out of, and clean the end of the small connecting tube, replace it and it works, but sadly very rarely does this work. Get yourself a new gauge and if this still reads zero after fitting it, call out a trained engineer.
I’m all for DIY. But honestly in this case you shouldn’t even be taking the cover off the boiler. Get a GSR out :))
Gauge is below the boiler no covers need to be removed
It was suggested that this guy cleans out tubes going to pressure gauge. Can that be done without taking cover off?
Yes as it's threaded into the valves below the boiler
Reply to Boiler Combi 24, pressure indicator always pointing to 0 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have been facing central heating low pressure on unvented hot water RM Cylinders but can't see any leak on the PRV, expansion vessels and plasterboard celling. I have got unvented pressurized RM Cylinders hot water system with 27KW Worchester gas boiler with expansion vessels . When...
losing pressure
L
Hi All Bit of an urgent one being that time of year and can't get a plumber out until after xmas even on an emergency callout I have just tried to turn on my CH for the first time this year as I have a number of guests coming for xmas dinner but even after an hour all the rads are stone...
I have just had a boiler, hot water tank and power shower pump replaced on advice by my plumber. I have two separate boilers, heat/hotwater systems in the house. This boiler was replaced by a combi boiler as it only heats the lounge and master bed and provides hot water to en-suite bathroom and...
I have a Combi boiler and, a few minutes ago I turned on the hot tap in the kitchen and the water was far from hot. In fact, it was decidedly lukewarm. I checked the boiler and the tap icon was lit up, showing it was delivering hot water to the taps and I could hear the boiler running and the...
My Grant combi oil boiler is giving me quite a headache at the moment. When I returned home last Friday I'd no heating or hot water. An engineer called the next day and diagnosed a faulty pressure switch. This was changed and everything seemed ok. However then the boiler began to lose pressure...
