Discuss Boiler is it the right size? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone and thank you for any advice and suggestions in advance.
We moved into our property 4 years ago and had the CH upgraded to a system boiler and tank system. It has never warmed the house properly but we just thought this was due to renovating e.g odd rad off wall, bare floor boards, old windows that need replacing.
Whilst looking for new rads I came a cross a site that worked out the btu for each room in total 93,234 btu this is for a large 6 Bedroom house with 2 living rooms and large kitchen. However after checking the output of the boiler (Worcester Bosch greenstar 24cdi) 81,891 excluding any btu for hot water, it seems the boiler is not powerful enough. What do you all think?
My advice would be to ignore the app's and get a Heating Engineer to look at it. You might need to pay if all you require is calcs but there is a lot to be said for experience.
Copper cylinder?
A Heating Engineer will be able to tell you everything you need to know in a report.
Things such as Heat losses, Boiler size, required emitter sizes, what output you have from what's in place already etc etc.
That's my advice.
That's my advice.
Also chances are the expansion vessel and pump are undersized
Online rad calculators are notoriously inaccurate. Frequently provided by rad manufacturers/retailers, who want to sell their products.
The Baxi Whole House Boiler Size Calculator uses the method developed by the Building Research Establishment to calculate the total heat loss from the house, including an allowance for hot water.
I do, still have my imperial ones
Thanks to all that replied and thanks once again for the advice. I’ll get a heating engineer to do a report. Does anyone have any recommendations for one near barnsley/sheffield area?
I would say almost certainly your undersized what cylinder to you have ? Set your hotwater timing at a different setting to your heating that way the full output will go to the rads turn down any unused bedroom rads and uninhabited areas , system boilers are renowned for running out of pump power rarely fit them myself preferring a seperate expansion vessel and unvented kit and a properly sized pump . kop
Do the whole house calculation.
But your boiler does look small for a 6 bed house. It also could be a problem with undersized pipework and installing a larger boiler would not make any difference.
If the boiler has 'never warmed the house properly', which is what you said, it is probably an issue with the circulation, emitters, or controls. If the 'house is okay until the really cold weather comes' then the boiler gets added to the list of possibilities.
A useful piece of information when investigating such issues is to record how much gas you use over a week and the average temperature for that week. There is no need to calculate the losses for your own house, you can just measure them directly.
It does sound undersized, when it's cold shut down the TRVs in three of your large bedrooms and see if that makes a noticable difference.
I don't know anyone over there but when you find someone, in addition to everything that has been mentioned they should look at pipe sizes.
Out of curiosity what are they leaving the Boiler now?
Reply to Boiler is it the right size? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all. I recently upgraded our CH system, but rather than the expected drop in gas consumption, Octopus is saying we're using roughly 30% more! The installer has said they can downrate the boiler, but to my mind that addresses maximum consumption, not any inefficiencies there may be relating...
Hi, I am not in UK and the rising fuel and gas prices are forcing me to change my boiler to an efficient one. Right now I have an old non condensing boiler which is way oversized and consumes 1.75m3/hr so I am looking at an efficient gas boiler to support attached load. I plan to buy it from UK...
2K
The recommended radiator size for my bathroom is 2500BTU. The rad. I have chosen is available in 2258 BTU and 2741 BTU. The smaller one will fit better but I would not want to compromise the heat output by choosing it just because it looks better in place. Bathroom size is 7' x10' x8' high with...
Ive got a new replacement boiler to install and the Energy Saving Trust whole house boiler sizing is no longer being allowed to be used to correctly size new boilers. Apparently there is an app you can use for room by room calculation anyone with a link. I've looked online and keep just...
Hi all first post looking for a bit of advice. I have a recently bought a 24 year old 4 bedroomed detached with1 bathroom in the (border town of Berweck) it has 14 radiators,and a heat only full system,but it was running off a 24k for the last 12 years I was told, and its now not working, the...
