Discuss boiler manuels in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Bugsbunny
Need installation and servicing manual for Sime Friendly format 80
Have you tried the manuals library, they are online, really good and a hell of a lot of boiler manuals
Reply to boiler manuels in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Am I the only one struggling to find appliances' manuals online? I know it's hard enough with cookers and old gas fires but I've just been unable to find the manual for an Ideal Exclusive. I thought I had found it but it turns out the GC number was different. Given the law says "refer to MI"...
Can anyone help me identify which tap/connection it is to top up the system as the level has dropped quite a way below the red marker for the cold fill pressure on the gauge? Boiler was installed approx. 2014. I've looked in the manual & online but can't find anything. Many thanks
I would like some guidance regarding the Worcester CDi 29 Classic boiler. According to the manual it has a holiday mode and frost protection mode for when away for a period of time such as a holiday, both of which disables the central heating system and both require it to be set manually. I have...
Anyone familiar with servicing SIME Format 30HE? I had to shut down a boiler today as it was using far too much gas and I was unable to identify the fault. The CO readings were totally fine but the gas rate was coming in at around 38kW. Has anyone come across this before or have any idea what...
Deleted member 120897
Hi wonder if anyone can help. Had no issues last year. Have Valiant ecoTEC plus and Drayton thermostat. I have tended to leave thernostat and just turn boiler on when needed. Its showing 14 and when i set it higher sometimes it comes on sometimes it doesnt. Sometimes it starts and then...
