Discuss Boiler Pressure Problems. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
lupieloo
Hi.
I'm having problems with finding the reason for that pressure to keep falling to 0. The customer rang me saying it took 4 hours for it to drop but I'd image he had it on all that time. When I went out I checked the pressure relief valve, drained the boiler and recharged the expansion vessel to 1 bar which I charged to 1 bar (might be slightly too high), couldn't find anything leaks. I forgot to check if the pipe to the expansion vessel is blocked but could there be anything else at fault?
Charge the system up. Isolate the flow and return valves. If it drops upon opening them some hours later then it is a leak somewhere other than the usual boiler prv issues
Reply to Boiler Pressure Problems. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Good afternoon, I am experiencing a pressure issue with my heating system and was hoping to receive additional insight as to what the problem could be. We have a biomass boiler and stratification tank set up and recently had an issue with boiler pressure dropping off when the system was cold...
I have been facing central heating low pressure on unvented hot water RM Cylinders but can't see any leak on the PRV, expansion vessels and plasterboard celling. I have got unvented pressurized RM Cylinders hot water system with 27KW Worchester gas boiler with expansion vessels . When...
losing pressure
L
the pressure of my boiler looks unstable After i re-pressurize to 1.5 bar, using tap is ok without problem. but when turn on the central heating, the pressure rises over 2 and the error code 117 showing water pressure high After i did the bleeding and re-pressurize to 1.3 bar, the heating is...
M
Hi, we have a back combi heater. Whenever the heating comes on it seems to lose pressure within a few hours and I have to refill each morning. The boiler seems to function well, and the pressure only drops with the heating and not the water being on. Ie it started last winter and was then...
Hi all not a plumber but am an engineer I have pressure drop in the system Worcester Bosch came back after repressureising the expansion vessel and he replaced the heat exchanger element. The boiler is coming up for 15 years old. The boiler was going below one bar and not increasing when...
