Discuss Boiler service advice in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
alanm
Hi All looking for some advice. Boiler has broken down after 20 months but has a 7 year warranty I have had the unit serviced but just noticed when looking at paperwork the the print out is dated October 2017 when the service was carried out in October 2016. Does this matter or is it just a case that the engineer has not updated in meter date. Concerned the manufacturer will use this to get out of the warranty. Boiler is a potterton. Any advice would be grateful
Just call the customer support number for Potterton:
Repairs
and they'll get you sorted out.
It's always wise to keep copies of receipts for servicing and check they are correctly dated at the time they are issued.
Thanks Chuck couldn't find the receipt but luckily the engineer had stapled the print out into the service book. The service book is filled out with the correct date but the print out was one year out to the day. Have contacted potterton and a engineer is coming out tomorrow so can't fault service only noticed today when I was get the paperwork ready for this visit and got a bit worried.
cant see it being a problem contact potterton customer services they will book you a service call cheers kop
Reply to Boiler service advice in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone! Parents not used the boiler since 2013/2014, since installing a new wetroom for them they have now decided its worth getting the boiler running again. The only reason it has not been used i so long is the the zone valve kept getting stuck (would have fixed this myself if i knew!)...
Hi, I need some urgent advice. I've Just come home after going out for evening, to discover hallway floor and kitchen floor covered in water. On further inspection I discovered that water was coming from boiler cupboard. On looking in boiler cupboard I found boiler has started leaking water...
Hi need some advice on this odd story, I had a Bosch boiler installed just over 2 years ago by Governments home energy scheme. The company passed all checks, provided certs etc. The government/Green scheme sends 2 other gas boiler engineers to double and triple check things and One was Bosch...
Had conventional boiler and tanks removed last year and new combi fitted and just recently had it serviced but the guy who did it has given me a gas warning notice for at risk as the outside wall meter box has been drilled through for the gas pipe to go horizontal straight to the boiler. The...
Hello The heating side of my Ariston Combi A23 has stopped working since a new 3 way valve has been installed. It's been a hugely reliable boiler up until now with regular servicing. When the heating is turned on the boiler ignites and looks to start up but then a few seconds in, knocking sounds...
