Discuss Boiling Water Everywhere Except Shower in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. Nickmorris6
    Nickmorris6 New Member
    Hello,
    I have a combi boiler that goes directly to the shower (normal - not electric).
    I can get boiling water everywhere, except the shower where it is just warm.
    I also get luke warm water when running the cold tap in the kitchen sink initially too (only mentioning incase relevant).
    Can anyone help me please? I have attached a photo of under the shower if that helps!
    Can I fix this? I am usually good with DIY, however have very little plumbing knowledge.
    Any help would be most appreciated.
  2. ShaunCorbs
    Any chance of a pic of your shower
    Sounds like the cartridge in the shower has gone
  3. Nickmorris6
    Thanks for your reply. Please find attached. It's all newly installed about 3 months ago but fed up of just luke warm showers now!
  4. Gasmk1
    Gasmk1 GSR
    check the shower when running is the hot pipe feeding it really hot if so then your problem is either the cartridge or the unit itself. if its only been in 3 months then still under warranty
  5. Nickmorris6
    I have also attached under my boiler if that is useful where they put in a stop cock
  6. townfanjon
    townfanjon Trusted Plumber GSR
    Has it been like this from new or was it ok and its now pants
  7. Nickmorris6
    It's never been nice hot unfortunately, just warm ish.
  8. townfanjon
    Probably just wants calibrating, if you still have the instructions it will tell you in there, but basically just take off the temp knob , turn the splines underneath untill the flow gets hot , test with a thermometer to around 42 degrees and put the knob back on .
  9. Nickmorris6
    Ah I wish I had the manual! Thanks for your help, I will try and contact victorian plumbing and ask for a manual
  10. jtsplumbing
    jtsplumbing Plumber GSR
    That explains why its not working its from Victorian plumbing Chinese import, either it wants calibrating or filters are dirty if none of these take it back
    • Agree Agree x 1
Loading...
Similar Threads - Boiling Water Everywhere Forum Date
Worcester oil boiler and water immersion heater question Oil and Solid Fuel Forum Sunday at 9:46 AM
Driveway Shared Water Supply Leak Plumbing Forum Thursday at 10:18 PM
