Discuss Bosch Worcester Greenstar i System Boiler Ventillation requirements in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Meeko
Hi all,
Looking for advice on the ventillation of the Bosch Greenstar i System Boilers. I've had one fitted into a new home I've purchased and the developer missed a course of bricks out so the ceiling is too low to install a vent to the outside. The boiler is in a small room (2m x 1x1.8m x 2.2m high). They have fitted a pipe to the outisde that goes via the adjoining garage (at ceiling level) and the pipe is rectangular so it can fit in the small ceiling void (approx 4cm x 20cm cross-section). They have fitted an extractor fan (i.e. meant for bathroom) on the end inside the room where the boiler is installed, which is operated by a switch.
This is a workaround since it cannot be vented externally - is this acceptable? It seems stupid to have to run an electric extractor fan when the boiler is on?
Many thanks!
Are you talking about an additional vent or the flue pipe
Put a pic of what you mean / pipe
It's an additional vent in the ceiling. They have used the following adaptor to convert the round hole for fan attachment into a rectangular shape where the slimline duct then runs through ceiling void, through wall in to garage, across garage ceiling and eventually through exterior wall.
https://www.electricalcounter.co.uk/products/Ventilation/Extractor+Fans+%26+Ducting/Manrose+Ventilation/Ducting+%26+Accessories/Ducting/Low+Profile+Ducting/Connectors/204+x+60mm+Elbow+90%B0+Bend++Connector+-+5%22+Spigot/378440228?gclid=CPGb0YjRksoCFQQUwwodt-YD4A
I thought for a moment a space saving rectangular balanced flue was quite a good idea but no such thing exists to my knowledge.
You really must post pictures so we can accurately assess the installation for ourselves.
I'll try and get pictures this evening but it's unlikely I'll be able to gain access to the property. The boiler is wall mounted with a balanced flu that exits through a side wall. So the basic question is are building regs complied with if a ceiling mounted extraction fan is used for ventilation, rather than a direct vent to the outside (if that explanation helps)?
Sorry wrong end of stick thought it was for flue gases, as Steve says below many boilers don't required a vent. Is it a utility room?
Yes the boiler is in a small utility room (room just contains cupboard with system boiler and a washer/dryer). I'm not clear if Bosch/building regs dictate this boiler needs ventilation.
Screen Shot 2016-01-05 at 14.05.58.pngThe boiler doesn't need additional ventilation as it can be fitted in an unventilated cupboard as long as there is enough clearance around it (specified by manufacturer) for servicing.
If it isn't fitted in a cupboard then no problem.
Make sure you get the Benchmark form filled in otherwise boiler won't be covered under WBs warranty. Sounds like the developer hasn't use a GSR installer otherwise he could have answered your question
@WW Ehh? There is no inference that the boiler has been poorly installed.
The OP just assumed (incorrectly) the utility room extractor needs to be on when the boiler is running.
Just seems strange that the OP is even getting involved with ventilation when it's not needed. So I interpreted that as no-one onsite is qualified...
Surely the extractor is for the washing machine and or drier. But I would still want to get my hands on the ticket before I exchanged!
Reply to Bosch Worcester Greenstar i System Boiler Ventillation requirements in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just had a new Worcester Bosch Greenstar 30Ri fitted with the magnetic filter. When the system is running the boiler is so quiet but there is a sound of trickling water through the filter, loud enough to hear quite clearly and is pretty annoying. I wouldn't of thought trapped air would sound...
Hey guys in the know. I have paid for a heating and plumbing contract and had to pay my excess 3 times for the same thing still not fixed. The issue is quite simple to repair not sure why any one of the 2 plumbers could not fix it. Why am I paying for cover. The auto air vents in part of the...
I need a little help if possible as I am trying to check that my current system is running efficiently but not really sure how to check, sorry if this is a long one and I have tried to contact a Honeywell connected specialist but they dont seem interested unless installing a new system and the...
2K
Hi I seek some advice on replacing an existing regular boiler. I currently have an old Potterton 10-16 Netaheat electronic, which is around 35 years old and still working OK. It is fitted to a std 'Y' plan system with boiler in utility room and separate hot water tank, pump, valve etc in...
We are experiencing an issue with CH short cycling on a Worcester Bosch Greenstar 25i ErP boiler. From a cold start the boiler fires for only ~25 seconds before exceeding the set CH flow temperature and entering it's 3 minute short cycle programme. As soon as the short cycle programme kicks in...
1K
