E
erpkid
A quick snatch saves a wet lap
Discuss Brass fittings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
True but if it was a mansion you went to it would hardly be a 100 pound carpet lolyou've only got her word for the value of said carpet :angel_smile:
Would you snatch even if miss dopolopolas had a 10 thousand pound carpet in the room you was working in
Peel the carpet back a few inches from the pipe and stick a towel down behind it.
I'm sure she won't mind a few nice black marks on her nice £1000 cream carpet haha if its a cream carpet don't snatch!
Im my position what would you do because i dont have a freezing kit yet lolif its a £1000 carpet, charge accordingly and freeze it
Well rick if I'm completely honest I would drain system down. And I know people are thinking why, I just have never used bungs yet and prefer draining as I would have perfect control over the situation. I am fitting a new rad on a sealed combi system Wednesday and I'm gunner try just releasing the pressure and having one end open at a time.
use a carrot and spudWhy don't you buy a set of bungs rick and practise using them at yours assuming you have an open vented system. Make sure you have faith in what you use round customers houses.
A parsnip works best and besides it counts as one of your five a day when you've finished. Just don't eat it after bunging a macerator though.use a carrot and spud
If the rad is the same width just isolate valves and crack a nut and drain the rad opening the bleed to let air in. Catch water in a tray fill a bucket and then remove rad and hang new one in same place
Yeah no AAV's and floorboards and bare plaster walls so nice and easy.
Auto Air Vent in this case. Can also mean Air Admittance Valve, commonly known as a "durgo valve" used on soil pipework.Whats an AAV lol
College taught us to isolate the lsv and trv crack open the two nuts to the rad slightly! lift the rad of its brackets and lower the rad to the floor.Completley disconneted the two nuts from the rad and lift the rad up so the valves are pointing up then pour into a bucket.
Im thinking you mean isolate the valves disconect the nut on the trv valve to the rad let the water pour into the bucket using the rad key to open the air bleeding valve to control how quick it comes out then remove the rad completley?
Reply to Brass fittings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
