Discuss Brazing Copper to Brass Flanges in the Plumbing Jobs | The Job-board area at PlumbersForums.net
cr0ft
Hi again. Another few obvious questions for those who know the answers I'm sure :)
1.) Is there a maximum pipe diameter where fittings can be soldered before it stops working?
2.) For brazing as opposed to soldering, what filler would you use to join copper to brass? Also what flux do you use please?
Am looking at an easy way to join copper to brass flanges in house and brazing seems a lot easier than welding!
I'm assuming a normal Superfire blowtorch with MAP gas will be fine for brazing?
Thanks for putting up with my questions. I feel like I'm learning plumbing all over again moving to larger commercial systems from domestic.
press all day long and no map wont be the best
nope
normally brazing rods eg bronze etc but you have to be careful on potable water need special ones special flux as well
oxy acet you will need
I dont like to solder above 42mm
As Shaun says oxy-acetaline needed, no flux just a good clean up of pipe and fitting and silver solder rods. CP4 rings a bell
Thanks all. We have a pressing kit (REMS with XPress heads) and I noticed they do pressed flange kits. Just seem stupidly expensive but I guess I'm not paying for them!
normally dont use any flux on copper to copper joints but like some on copper to brass ones
better than trying to get them to sign off on hot works permits etc
have a look at female iron flanges
Might just use our pressing kit tbh. Where do you buy Yorkshire Xpress from to get decent prices??
bss normally
Brill thanks all. Much cheaper than I found before :)
At those prices it's not worth brazing is it.
no not worth the paperwork and hour to two standing around
bss are normally 10% cheaper but collister is only up the road from me
Reply to Brazing Copper to Brass Flanges in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi there, thanks for your time to look at this record long post!! I work on the operational management side or a small building contracting firm. This question is for my own house setup. We are really fortunate to have a large house, about 5,000sqft in total over 3 floors. It was built around...
1K
H
HRP123
H
Question for the UK Plumbers: Are you ever using 316 grade stainless steel tubing for water piping? How are you joining it? How cost effective is it in the UK compared to say soldered (or press joint) copper? Is anyone commonly soldering/brazing it or just using press-joint of grooved...
2K
Hello, I'm installing a shower tray on a 4m run from the soil stack. Building control have specified 50mm pipe so that's what I've got. However, the 50mm pipe means that the only way they would allow a hole of this diameter through the joist was to put a doubler on it, which is OK, but just...
2K
Hello everyone. Could someone offer me some advice as to how to deal with the following, please? I'm removing a radiator from an en-suite. It will not be replaced. There is speedfit micro bore behind it into the plasterwork and it may or may not be push fitted on to copper, I'm unable to see...
3K
