Discuss British Gas contract servicing work, in the Plumbing Jobs | The Job-board area at PlumbersForums.net
royalmike
British Gas contract servicing work, anyone on this board working for them as a contractor that would like to tell me what there opinion is? Have ther induction in two weeks.
I did it a fair few years ago. I quite enjoyed it, takes a while to get used to working on a laptop. Once you pick it up though, its easy money.
Thanks for the reply
How many services a day would they give you, and how much work.
Normally 7 or 8 as standard, but you can request more if you want. Will you just be doing services or breakdowns too?
Was told it's only services they contract out now. Think the job agency are getting a cut of my earnings that I am not to pleased about, things have changed at B.Gas since I worked there in the 80"s
I got asked the other week.
Did the telephone bit.
Couldnt be arsed to go to leeds for an interview so didnt take it any further.
The money was a bit tight but you would get volume
It depends if you go through a agency or direct to them. I did it about 6 years ago now, and subbies were earning £18-25 a service.
Reply to British Gas contract servicing work, in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just been to a nightmare of a job! Had to carry out a service on the 2009 British Gas 330 + (GC: 41-019-11) It's a Glow Worm boiler. The boiler was flashing SE even before I arrived, which I assumed the service reminder needed resetting. After completing the service I contact Glow Worm to...
Had conventional boiler and tanks removed last year and new combi fitted and just recently had it serviced but the guy who did it has given me a gas warning notice for at risk as the outside wall meter box has been drilled through for the gas pipe to go horizontal straight to the boiler. The...
British Gas servicing the above boiler ramped up the boiler to maximum in the installer menu to do flue gas analysis. They also measured the working gas pressure on the gas valve test nipple. This fell to 8mbar on maximum and 17mbar on high setting. They then removed the isolation valve under...
My Mother-in-law was quoted £1,000 by British Gas to do a power flush on her system as her rads aren't performing well. I was wondering, as 4 radiators need to be upgraded to doubles, would this need to be done if they are drained off and replaced? How does one actually know it needs a power...
  • Locked
Hi, A little about the business: I currently own a plumbing business (website and marketing) - looking to target residential and commercial market (i.e. tendering to main contractors flats etc). My background is a commercial manager, I use to do plumbing years back so technically I would not...
