Discuss Builders not wanting to zone house. in the Plumbing Zone area at PlumbersForums.net
Ric2013 I don't think modern boilers have much of a requirement there is so little residual heat in the condensing exchangers.
The manufacturers may ask for a minimum flow rate to allow the electronics to control the boiler /pump outputs but this is better done by using hydraulic separation via a low loss head or close spaced (coupled) tees rather than a auto by-pass.
I was thinking of old cast iron boilers when I mentioned minimum heat dissipation, though I note the MAIN HE 24 heat-only boiler has a requirement of a 4m run of 22mm pipe to provide a suitable by-pass. That said, point taken: the MIs do not say anything about not being able to insulate the bypass circuit (as long as there is no plastic pipework used in the system).
Reply to Builders not wanting to zone house. in the Plumbing Zone area at PlumbersForums.net
