Discuss Bus lane fine, Can i put it in the books in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Scott_D
Subscribed
I cut across a bus lane 3 meter before it ended and have received a fine
Can I put it in my books as an expense?
I understand that. But you made the decision to drive into the bus lane knowing that if you did there was a possibility you would get a fine. Personally if you were 3 meters from the end of the lane I would contest it.
It was an accident
Do you have an accountant that you can ask? I'm not 100% sure, but if the vehicle is registered to the company then you may be able to.
Reply to Bus lane fine, Can i put it in the books in the Plumbing Jobs | The Job-board area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
  • Sticky
