Discuss Cable to an electric shower in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Scott_D
Subscribed
A friend has asked if it is safe/allowed to run a surface mounted cable to an electric shower?
It's happened at his grandparents house down south and he is a bit worried
Said its surface mounted but in a conduit
Sounds rough but is it ok?
Yes ok normally done on social services grant jobs
I guess it doesn't matter if the outer coating gets wet
Trunking normally is ip 45 rated so other than sealing to shower it should be fine
Mira shower ?
No idea
I'm not involved, just got asked if it was allowed
Yep fine normally done if all the tiles haven't come off, I normally run the shower feed in the same mt4 normally
Reply to Cable to an electric shower in the Plumbing Jobs | The Job-board area at PlumbersForums.net
