Discuss Calor gas heater is smaller than recommended room in the Plumbing Jobs | The Job-board area at PlumbersForums.net
What is the reason they give a minimum recommended room size? Are there any dangers involved in putting in a room that's smaller than recommended?
This sort of thing
https://www.calorgas-heaters.co.uk/...-seasons-warmth-portable-calor-gas-heater.jpg
[thread title should read Calor Gas Heater IN Smaller Than Recommended Room]
Yes. It is a flueless appliance. It needs the correct ventilation.
Without that, the air will become vitiated and CO will be produced. On top of that the CO2 levels could become too high.
Both are a danger.
Thanks, very helpful.
My mum just downsized her house and wants to use one in a much smaller living room. Have told her not to use until we check the size against minimum room volumes in manual
Reply to Calor gas heater is smaller than recommended room in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Locked
Morning all I have an issue with a very old (~ late '70s) Superser gas heater that has just cropped up following a bottle change. In short, it seems that the gas supply is too much and the pilot light will not stay. When trying to ignite the flame seems very aggressive and as soon as the...
12K
Hi all. My mother has a large lounge with central heating. Because the layout forces a sofa to block a rad she also uses a portable gas heater in the winter months. She now wants to replace this with a fitted unit. The lounge has a faux surround on an external wall with no obstructions outside...
2K
Hi, some professional advice would be greatly appreciated, We are having an Unvented Cylinder installed into our 2 bedroom ground floor flat. I have had a few quotes and been given lots of differing advice, this always makes me wary, especially having suffered a history of poor quality work by...
9K
  • Locked
I recently bought a portable barbecue (the Char Broil Grill2Go X200 to be precise). This type of gas barbecue runs off of the so-called "universal screw fitting" gas canisters like the one pictured here: The screw fitting is otherwise known as an EN417 7/16" UNEF screw thread. With some...
2K
  • Locked
First time posting on here and I am after some help and advice on a project I have ongoing at home - a bit cheeky I know but as they say around here ‘Shy bairnes get nowt’! My children (10 and 8 at the time) were lucky enough to be given an above ground 15ft round swimming pool from some...
2K
