Discuss Can anyone help identify fitting pictured. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I’m trying to find out what the fitting is in the picture. It’s fairly old (maybe 80’s) and has started leaking water. I figured it’s some kind of valve but can’t find an old picture of it anywhere. It’s located next to the old concord boiler in the kitchen.
Any help would be much appreciated.
Judging by the holes I'd say most likely a pressure relief valve. If it's like one I had many years ago it has a conical seat with a corresponding spring-loaded plunger. The plunger has a groove with an O-ring. You would need to drain at least partially, and undo the end nut. Put a spanner on one of the other flats to hold against yourself and avoid twisting the pipe. If the internals are what I think, you can renew the O-ring.
It’s an old 1/2 spring safety valve.
Seen on lots of old gravity systems. Touch it at you own risk, it will leak more. Best to look at the pipework and system and see if it can be capped
It is definitely an old type spring relief valve. I find them on loads of old oil boilers.
If it is still required then just fit a 3bar pressure relief valve if you can terminate the pipe from it.
It's a spring loaded Pressure relief valve.
Reply to Can anyone help identify fitting pictured. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
my bathroom sink (installed 2017) was broken recently and needs replacing. on inspection there is no brand name and only a few markings so I'm guessing its a trade sink that plumbers would buy. The sink has 1708 indented in the china which i guess is a model number but doesnt show up on google...
Hi , I'm wondering whether anybody can help me at all ? My boiler has started making noises which I am unable to identify. If anybody is able to guide me to the route of the issue itll be massively appreciated. I'm looking for an idea of how much it will cost to get it repaired. The water has...
Hi, hope all is well! I’ve fitted a compression cap on two of my shower mixer copper pipes (15mm). One of them has scratches and burring and is very slightly out of shape. It leaked but I added some PFTE tape over the olive and it seems to of done the job. However… I’m tiling the wall and...
Hello, I need some advise, will greatly appreciate if someone can help. My mixer tap is leaking from base want to renew it. However the tap cold/hot water feed is connected via connectors/fittings as shown in attached picture. Can anyone please advise how to disconnect tap from these fittings as...
