Discuss Can I install a Thermostatic Shower? in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. SnakeDoctor
    SnakeDoctor New Member
    I have a Vented Gravity Fed system where the bottom of the Loft Tanks is 2.3m above the the Shower Mixer. Can I install a Thermostatic Shower and where would be a good place to get a modern looking External Mixer, Dual Head Shower?
    Thank you
  2. jtsplumbing
    jtsplumbing Plumber GSR
    Get one from any good plumbing supplies, go for a known make and tell them its for a low pressure system.
    • Winner Winner x 1
  3. leelister6
    leelister6 Plumber GSR
    You need balanced supplies as well
    • Agree Agree x 1
  4. steadyon
    steadyon Active Member
    If the shower mixer valve is 2.3M below the cold water storage cistern, (CWSC) then the shower head is likely to be 1.3M below the CWSC. This will give you a pressure of approximately 0.13 bar. You need to be sure that the shower you choose will give a decent flow at that low a pressure.
    Assuming the vented cylinder is fed from the CWSC, than you have balanced supplies.
    You could fit a shower pump to improve pressure, but any pump would require dedicated feeds from the CWSC and from the hot water cylinder, the latter via a special flange.
  5. Darren Jackson
    Darren Jackson Plumber GSR
    Only if the cold feed is also taken from the CWSC to the shower.
    • Agree Agree x 1
  6. fixitflav
    fixitflav Member
    I have a gravity shower with similar head and it's fine. Many years ago I installed one in a previous house (same head) and wanting to go the whole hog I got one with separate flow and temperature control. It was fine but I now realise the flow control was unnecessary as while the flow is adequate, you'll never want to turn it down. So the current one has 1 knob, turn it ACW and cold flow starts, turn it further and temperature rises.
    If you haven't already planned the piping, you can take the hot supply from a tee on the vent pipe from the HW cylinder. Then you can run both pipes in the loft, to directly above the shower.
  7. king of pipes
    Have a look below on victorian plumbing it can be done . kop
Loading...
Similar Threads - install Thermostatic Shower Forum Date
10% Off GID1 Best Selling 'foundation' Gas Installer Manual Plumbing Forum Today at 11:25 AM
Belongs in "Installer" eye spy section Gas Safe Registered Plumbers Only May 31, 2018
  1. installing a thermostatic shower in a gravity fed system
