Discuss Can I Swage Gas Pipe? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello new here, can I swag gas pipe instead of using a fitting?
Are u gas safe registered ?
Pb plumbers work
Decent fitter pb, almost as good as me. He loves to promote the latest gear tho. Swear he's sponsored by the sheer amount of kit he has
He is
Just out of interest - off topic.
What are your copper tube wall thicknesses?
We measure our pipe OD.
1/2" - 0.91 mm
3/4" - 1.02 mm
1" - 1.22 mm
We always expand copper ( swage ) and have never had too many issues
I suppose expanding (stretching) the pipe for making it into a socket is no different than bending pipes with a bending machine, as still being stretched and made thinner.
But what is the cost of 22mm end feed connectors? Almost nothing.
I see one slight advantage to swage pipes that are rising vertical, - you have a vertical top joint only to solder and the solder will flow down easy, as opposed to also having a joint to solder from the bottom.
If you are counting how much solder wire and flux you are saving by using a swage, then you must be on a very tight price
1/2" - 0.91 mm
3/4" - 1.02 mm
1" - 1.22 mm
I think 15mm is 0.7, and 0.9 for 22mm, so a bit thinner than your stuff. I'd be tempted to do it on water (it looks good), but only if I could get a squeeze-operated expander. Seen one in books, but not for sale. Can't be bothered to have to start hitting an expander with a hammer while supporting the pipe somewhow.
Swage pipe for plumbing and heating. If the copper is good quality then a swaged joint is fine and IMHO looks good. If you have a bender, springs internal and external with different shaped knees to get different bends, and swaging tool then some quite dandy pipework can be achieved. Mind you I am getting too old to do 22mm too much this way !
Reply to Can I Swage Gas Pipe? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
